I can't find a website with exploded parts diagrams for Fords. It sucks! That boot is common and you may find a Dorman part that works. I would grab one from the junkyard since I go occasionally.
It likely will be part of a harness when you do find it. I'd take boot in local parts store, see what they have. Your system will work fine without as you search for a replacement.
Is it the alternator, battery, ECM or BMS issue. New vehicles have a battery management system now and after replacing the battery you need to reboot the BMS to allow full charging. After buying a new battery you also pay for the reboot. What's next, paying to put air in your tires lol.
Everything is designed as remove and replace today. I know of no automotive repair shops that will rebuild anything today. The time and labor is the most expensive part these days.
I think the intent is to reduce the total part count. Reduces the labor to produce.
Yep, time is quite literally money in the automotive repair business. All jobs are quoted based on time required to do the job. A good tech will almost always beat the book time, and get more jobs in. In most cases the parts are only a fraction of the cost of repair jobs. So, now shop is going to invest an hour or two, at $180 an hour to rebuild a $100 dollar alternator, starter, etc. They will replace the part with a new or already rebuilt one, and trade the one that was removed for a core credit. Most DIY guys do that now.
There used to be a business in San Antonio called S.X. Callaghan. They would rebuild just about anything that had an electric motor. They would rewind the coils, replace bushings, cables, diodes, etc. It got too expensive to operate, and went out of business. The would even fix vacuum cleaners, electric fans, weed eaters, you name it, if it had an electric motor in it. These days, the cores are sent to Mexico or Asia, and the rebuilt units are sent back here. All the other electric driven stuff gets thrown away when it breaks. Soon, sadly, that will include electric cars.
