Under seat sub boxes
Old Apr 28, 2026 | 02:40 PM
Duke5A's Avatar
Duke5A
Anyone ever install subs under the bench seat? I have a 10" sub sitting on the back bench seat in the center right now and I want to reclaim the space to be able to fold the seat down without much fuss. I've seen installs in other trucks before, but never an OBS.
Old Apr 28, 2026 | 03:27 PM
90project5.0's Avatar
90project5.0
Single cab or 4 door? I had one of these under the seat for a short period:
There was barely enough room for that. I couldn’t imagine a normal sub fitting under the seat. I have a single cab. I ended up building a custom box for a normal 10” behind the seat.
Old Apr 28, 2026 | 04:31 PM
Duke5A's Avatar
Duke5A
Probably should have lead with that. It's a super cab. If I can get a 6.5" sub under both sides it would be enough.
Old Apr 28, 2026 | 05:19 PM
90project5.0
dimensions of usable area under? If you can fit a 6.5” sub, you can fit an 8”.
What is the usable area behind the back seat and cab wall?
Old Apr 28, 2026 | 07:47 PM
Duke5A's Avatar
Duke5A
Different size subs have different volume requirements for the box if they're to sound correctly. I made this mistake on another project car making the box small enough to fit under the rear package tray. There was space to use, but it would have made for a complex box design. Trying not to do that again.
There is zero room in the back if I'm to retain the ability to fold the seat down flat. I was just curious if anyone here had done under seat installs on a bench seat before. I'll just have to pull it out and measure, no biggie.
Old Apr 28, 2026 | 07:52 PM
90project5.0
Sorry I wasn’t help! If you post up the dimensions, I can toss ideas if you want. I used to build/install car audio back in the day.
Old Apr 29, 2026 | 12:52 PM
monkey-1's Avatar
monkey-1
Kicker hideaway. Fits perfect:
Kicker HS10 powered hideaway sub. Fits perfect under the middle seat.
malcolmhoule
Sep 24, 2024 03:58 AM
TestPilot57
Sep 8, 2024 03:22 PM
prerunnerswag98
Jul 2, 2013 07:45 PM
dylanellis
Apr 15, 2012 09:55 AM
Munkey
Apr 29, 2008 10:57 PM
