CAPTAINS SEAT?
Old Sep 14, 2024 | 02:07 PM
malcolmhoule's Avatar
malcolmhoule
4wd Low
CAPTAINS SEAT?
IS THERE SUCH A THING? MY TRUCK HAS A BENCH SEAT WHICH I WANT TO REMOVE AND REPLACE WITH A SINGLE CAPTAINS SEAT - IS THIS POSSIBLE? ANY SUGGESTIONS WHERE I WOULD FIND SUCH A SEAT?
Old Sep 14, 2024 | 06:27 PM
Olds64's Avatar
Olds64
There were bucket seats available in our trucks. The included center console was next to worthless for holding sodas and brick-a-brack.
Old Sep 21, 2024 | 08:55 AM
WCMtn1990's Avatar
WCMtn1990
I think installing buckets in a Reg cab requires either some custom work or a 40/20/40 bracket. A single bucket I think would have to be custom if you wanted the passenger side empty. My truck is CrewCab but I do believe the reg cab shares the same floor pan and the PO of my truck installed buckets on to the bench bracket with some pieces welded in so it can be done but again a solo captain's seat would likely need some custom fab work. Seat brackets for buckets are available at JY or ebay but the mounting points are all wrong for a reg cab.
Old Sep 21, 2024 | 12:44 PM
tjc transport's Avatar
tjc transport
i ain't rite
bronco seats bolt in on the outer seat mount holes. you will need to drill inner holes and re-enforce the floor around the inner bolt holes.
i used large body washers in my 88 when i replaced the bench with bronco buckets around 25 years ago.
Old Sep 23, 2024 | 05:32 PM
malcolmhoule
4wd Low
WHAT IS JY?
Old Sep 24, 2024 | 03:58 AM
tjc transport
i ain't rite
junk yard.
68_f100
Apr 7, 2023 10:18 AM
arrowheadfred
Aug 30, 2010 09:47 PM
