Sponsored by: Real Truck
DASH GUAGES
Old Apr 27, 2026 | 06:28 PM
norman1966's Avatar
norman1966
4wd Low
DASH GUAGES
changed motor and wiring all dash wiring from a 5.4 2006 superduty into a 2005 deisel truck no speedometer no guages work at all dash lights battery seatbelt lights work had to hot wire power windows need fuel guage badly
Old Apr 28, 2026 | 06:46 AM
Baylinerchuck's Avatar
Baylinerchuck
6.0 is a different animal. PCM, FICM, cluster, trans etc all work together. Not sure if the 5.4 is the same protocol, or even on a CAN.
Old Apr 29, 2026 | 03:51 PM
norman1966's Avatar
norman1966
4wd Low
swapped the 6 litre for 5.4 tranny bolted right on works fine had to change all wiring dash everything under hood gas lines and tank plugs for fuel pump and tail lights did not work ? pins in wrong location in plug i will check it later on biggest concern is no guages speedometer or rpm it runs good i hotwired fuel pump for now
mr78F150
Jun 20, 2015 09:32 PM
Magic Smoke
Dec 11, 2010 02:20 PM
Corner Gas
May 7, 2008 05:36 PM
Enzo500
Jun 15, 2006 09:55 PM
fseries
1997 - 2003 F150
Aug 3, 2005 10:40 PM
