2012 E350 vacuum can
Old Apr 24, 2026 | 08:54 AM
tjc transport's Avatar
tjc transport
i ain't rite
anyone have an easy fix for the leaking vacuum reservoir can?
our line stripping van has gone from once in a while defrost only to fill time defrost over the past 3 years.
i was thinking of making a new tank from 3 inch pvc , 6 inches long with caps on both ends and nipples glued in one of the caps then mounting it under the dash or firewall in engine bay. one nipple connected to intake and the other connected to HVAC controls in cabin.
Old Apr 24, 2026 | 10:48 AM
Don Ridley's Avatar
Don Ridley
I made a similar vacuum canister and it seemed to work well. But you can buy several configurations of vacuum cannisters that hold more volume, mount easily and cost about $20. The PVC pipe and fittings cost about the same. Of course, if you have all the parts laying around, that is a reasonable option.
Old Apr 24, 2026 | 01:51 PM
tjc transport
i ain't rite
wow, i was not aware they were that cheap.
where did you mount it?
Old Apr 24, 2026 | 04:27 PM
Don Ridley's Avatar
Don Ridley
I mounted it on the passenger side behind the plastic panel that faces the passenger. There is plenty of room around there and deep up into the kick panel area.
Old Apr 25, 2026 | 10:16 AM
manicmechanic007's Avatar
manicmechanic007
"Dumb things you see" has a YouTube video of him putting one on the floor above the RH wheel well area
Old Apr 25, 2026 | 11:37 AM
tjc transport
i ain't rite
saw a youtube i liked where he mounted it behind the passenger side of the dash to one of the dash support bracket bolts.
it is easy access and easy to mount. hardest part is cutting the old tube that goes to the controls.
shaunjpeterson
Oct 15, 2025 10:16 AM
VanGuyBob
Sep 19, 2025 06:11 AM
motor-officer
Aug 3, 2018 07:26 PM
jtexfisher
21
Jan 26, 2014 04:38 PM
Tailgate77478
Jun 19, 2011 09:07 AM
