Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
trans code for '79 LNT800 please.
Old Apr 23, 2026 | 06:13 PM
rusty valley's Avatar
rusty valley
Looking at the data plate, under the trans code is C. then a space, then 88, then we are under the axle code, N So, it looks like this, C 88 N. 79 f800 with big gas motor. Wondering what trans is in it, thank you. VIN. S80JVFF1548
Old Apr 23, 2026 | 08:36 PM
85e150's Avatar
85e150
S80JVFF1548
S80 = LNT800 gas
J = 475 4V Super Duty Gas V8 (an updated version of the 477)
V = Kentucky Truck Plant
FF1548 = 1979 numerical series, probably Spring '79 production. Numbers ran to "FK9,999" for that model year.
C = Fuller model RT-610 10 speed direct transmission. Does this truck have one or two transmissions?
88 = Not found. Could it be B8 or BB? Both those decode to tandem axles.
N = Ford 9,000 lb capacity front axle with power steering / OR / Ford 12,000 lb capacity front axle with power steering and "Optional frame color".
A nice clear picture of the warranty plate might help. Try to clean it off and make sure it's in focus.
Old Apr 23, 2026 | 11:06 PM
rusty valley
Thank you. I don't own the truck yet, its listed on Al Gores interweb. The seller says " 5&2 transmission". yet, photos show an air shift fuller spliter, and not the usual red **** of a electric 2 speed rear, so I guessed a 10 speed fuller, but which one? Also, its tandem axle.
The point of my inquiry is I'm looking for one of those "baby" 10 speeds. An RTO 6610 would be better than sex, a RTO 610 next, and any RT can be made into an overdrive with more money. Thanks for the info
Old Apr 25, 2026 | 10:42 AM
Destroked 450's Avatar
Destroked 450
Just find a RTO9513 and forget about a 10 speed
95 series was available with the smaller input shaft that would work with a 66 series clutch
RTO9513 gives you a lower low gear than the 10 speed and OD too
We pulled the RT 6613 out of my friends LT8000 and swapped in the RTO9513, one of the best improvements we did to that truck
Old Apr 25, 2026 | 10:56 AM
rusty valley
I love 13 speeds, but too heavy and big for this project, 64 f350, 5.9 cummins. Even the 613 gains 200 lbs by adding the back section for the 13.
I find rt 610's, but RTO's are scarce. I would like the newer 6610 if possible as I wonder if 610 parts are getting obsolete.
An RT 6610 only weighs 359 lbs, just a few pounds more than the Getrag on it now. The RT 610 weighs 425, from the fuller web sight, why would it be heavier, any idea?
Old Apr 26, 2026 | 09:16 AM
Destroked 450
Not cheap but a ZF6 would be my choice for that app
I’m running a ZF6 in my 12v powered F-450 tow rig and it’s been working really well towing loads grossing up to 30k lbs but normal average is lower at 24k lbs
Old Apr 26, 2026 | 10:29 AM
rusty valley
Yes, the ZF6 has high praise among users. I've never seen one for sale, although I've not been searching for that. I have an F800, 5.9 with a fuller 6 speed, thats not a bad trans either, but being an old truck driver I like shifting without the clutch. One thing I've learned from driving an old diesel Dodge Getrag for 15 years is that 5 gears ain't enough!
Old Jun 17, 2026 | 11:09 AM
rusty valley
Update for entertainment, The truck was at an auction. I drove up to verify the trans, and yes, an RT610. Its 200 miles from home, so I asked the auctioneer if there was a scrap guy nearby so I could just drive it over and pull my tranny and scrap the rest. He said, best thing would be to pull the trans on his lot, and he would resell the truck with no trans. I could not believe they would allow that in this modern world, but thats what I did.
Started at 9am, put a sheet of plywood across the roof, a couple big straps twisted together around the roof to hang a com-a-long from, dropped it down on a sheet of tin and drug it out with my pickup. They loaded it in my truck about 2pm, and home by dinner!
So, I won the truck for 775.00, pulled the trans, they auctioned it again, it sold for 650.00! So, after commission, I got my baby 10 speed for about 175.00. The oil in it still has some color, shift tower seems firm, but have'nt had a look inside yet. Fingers crossed. Need overdrive gears now
bfletcher101
Apr 23, 2020 07:26 AM
emgee
Sep 16, 2015 05:19 PM
snowdog79
May 9, 2006 11:38 PM
Ford204x4
Dec 30, 2002 12:42 PM
RockyBhm
Apr 14, 2000 10:03 AM
