Hub & spindle interchangability
Old Apr 21, 2026 | 02:51 PM
Marc49's Avatar
Marc49
8th Gear
The 8-lug front wheel hubs on my '49 F3 are rotted beyond saving. Looking for replacements I haven't seen anyone reproducing these, and also haven't found any decent used available. I have found 5-lug F1 hubs though.
I'm not opposed to using the F1 hubs and wheels if I can. Will they fit F3 spindles?
Old Apr 21, 2026 | 03:20 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
F1-F3 (Excluding Parcel) used the same 7RC-3010-A Front Axle I-Beam and 7HY-3105/7RD-3106/A8C-3105/6-A Spindle Assembly. However, things begin to differ at the hub assemblies. The F1 uses the 8C-1104-A hub, F2 & F3 the -1105-A hub.
Definitely give Chucks Trucks LLC a call and see what he has in his ever evolving used serviceable inventory.
Using the smaller hubs and brake hardware and whatnot will de-rate your truck.
Old Apr 21, 2026 | 06:09 PM
Marc49's Avatar
Marc49
8th Gear
Thanks, I’ll see what Chucks has. I’m still in the planning stage of this build so parts availability is definitely a factor.
Old Apr 21, 2026 | 06:42 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
I had a hard time finding F3 brake parts, I ended up putting a disc brake conversion on front. If you order large brake rotors you can get them drilled for your bolt pattern.
Old Apr 21, 2026 | 06:46 PM
52 Merc's Avatar
52 Merc
F1-3 all use the same axle, spindles, and steering parts. F1 and F2/3 hubs and brakes will interchange. Any F1 brakes, aftermarket disc kit, etc., will fit the same on a F2/3. Or if you need spindles for your F3, F1 parts are the same.
Old Apr 22, 2026 | 04:36 AM
fish pond's Avatar
fish pond
I de rated my M3 to 1/2 ton status,1/2 ton fit rite up.
put a 9" in the back as well,all 5X5.5.
good luck!
Greg
Old Apr 22, 2026 | 06:21 AM
Marc49's Avatar
Marc49
8th Gear
The more I look into this, the better de-rating looks. I like the look of the truck with the big 8-lug wheels all around. I'm also trying to keep as much of the original appearance of the truck as I can. But its becoming apparent that keeping this truck in its original configuration will result in a vehicle with maybe a 50mph top speed and brakes consisting of expensive and hard to find parts.
From what I can see browsing some older threads, a Dana 60 rear from a F250 would allow for improvements in drivability over the original Timkin rear but that still leaves the dilemma of finding suitable front hubs. F1 hubs and a 9" rear will mean an easier build with better options for wheels and brakes, and a truck better suited to Texas roads.
Still on the fence for now, and waiting to see what Chuck's has to offer. Not opposed to derating though the more I look at this.
Old Apr 22, 2026 | 08:29 AM
52 Merc's Avatar
52 Merc
If you want to keep your 8 lug wheels, there are good options for upgrading. As you noted, a later Dana 60 up to 72 will bolt right in and give you way better brakes and more friendly ratio availability. There is a company that makes a good front disc kit to match that's fairly reasonable and eliminate the front brake hassle. https://www.rusticdiscbrakes.com/pro...disc-brake-kit
Old Apr 22, 2026 | 02:31 PM
Brian1950F4's Avatar
Brian1950F4
That is the kit I was going to mention too. I have not used it, but it was the only one I found that kept my 8 lug wheels. 1948 F3
Old Apr 22, 2026 | 03:46 PM
Marc49's Avatar
Marc49
8th Gear
That's an interesting kit. I had no idea someone was making kits like this for F3's.
Old Apr 23, 2026 | 10:46 AM
tiger100's Avatar
tiger100
Marc49
I have a set of 8 stud hubs, from a 51 Mercury f2. I have the whole front brake system, including Drums, Shoes, Hubs, Dust shields and backing plates.. One drum is good , the other has rust divots (but could be machined, I haven't checked) shoes look pretty good. Hubs are fine, still have bearings. The only major drama is the fact that its all in Canada....... Let me know what you think......thanks
Geoff.
moejr
May 29, 2021 05:30 PM
AZAV8
Sep 6, 2011 09:50 AM
cloleson
Sep 7, 2005 08:07 AM
460Dennis
Jul 11, 2003 05:36 AM
