Surging
Old Apr 21, 2026 | 01:03 PM
sLackuR's Avatar
sLackuR
4wd Low
Surging
When I'm light on the pedal and keeping my foot fairly constant when leaving the line I am getting some surging. If I get on the gas I don't have any. My first thought was the TPS but I replaced the pedal assembly approx 10k miles ago. My last trip towing I did throw a CEL code p1211 but cleared it and it didn't return. Could this be a IPR issue? No forscan but I do use the torque pro app with the ipr %. I didn't notice if it was jumping or not while surging. I will check if it is showing anything weird.
Anything I can try to determine if it is fact the IPR?
Thank you.
Old Apr 21, 2026 | 01:36 PM
knottyrope's Avatar
knottyrope
turn key on to run but not start
press Accel pedal slowly 3 times
turn off and drive to see if it made a difference
P1211
Common causes include a faulty ICP sensor, a sticking Injector Pressure Regulator (IPR) valve, a weak High-Pressure Oil Pump (HPOP), or a restricted fuel supply
uplug electrical ICP and see if it runs better
Last time changing fuel filter?
more than 1/4 tank of fuel?
Old Apr 21, 2026 | 02:04 PM
sLackuR's Avatar
sLackuR
4wd Low
P1211
Tank is at half. I'll change fuel filter and try unplugging the icp. What does the pressing slowly on the pedal determine?
Thanks
Old Apr 21, 2026 | 03:37 PM
knottyrope's Avatar
knottyrope
its to recal the pedal to the PCM
Old Apr 24, 2026 | 02:50 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
When unplugging the ICP look for oil at the connection. If oily you need a new ICP.
droptoppop
Sep 23, 2022 04:38 PM
PJ-Hunter
13
Oct 22, 2010 03:41 PM
BoostRetard
Sep 12, 2010 05:20 PM
Joshglov
Apr 6, 2010 08:34 PM
chris86924
Apr 19, 2009 05:14 PM
