Sponsored by: Real Truck
Tailgate Lock
Old Apr 21, 2026 | 10:21 AM
flyboyike's Avatar
flyboyike
4wd Low
Tailgate Lock
This may seem like a dumb question, but I am wondering if on a 2003 F350 Lariat, the tailgate lock is supposed to operate together with the power locks of the cab. I am asking because on my truck, there does not appear to be any kind of wiring harness going into the tailgate to activate any sort of a power lock. Moreover, the lock does not seem to work with the key either, so the tailgate is permanently unlocked. I am starting to suspect the tailgate might have been replaced at some point, or at least the handle was replaced. So, back to my actual question, is the tailgate lock supposed to be powered on these?
Old Apr 21, 2026 | 10:40 AM
ashleyroachclip's Avatar
ashleyroachclip
Negative , the tail gate is not part of the power door locks .
as far as the tail gate not locking with the key ,how so ?
Does the key fit the lock ,turn in the lock ?
Old Apr 21, 2026 | 10:47 AM
flyboyike's Avatar
flyboyike
4wd Low
The key fits the lock but does NOT turn it. Works on all the other locks which leads me to suspect something got replaced back there at some point. Thank you for the answer re: power function.
Old Apr 21, 2026 | 12:12 PM
2015 F-350's Avatar
2015 F-350
What year, truck are we talking about here?
Old Apr 21, 2026 | 01:56 PM
marksman76's Avatar
marksman76
I believe you can buy and add a tailgate lock, that you would then have to custom wire into your existing harness.
A locksmith should be able to key tailgate to your key.
Old Apr 21, 2026 | 04:24 PM
WWR's Avatar
WWR
I'm in a similar boat with my '11
I apparently NEVER have time but have been meaning to see if there are "wafers" I can just remove from the tailgate lock cylinder. In that case any key would turn the lock, but how many thieves are going to try any old key? In my area, the answer is zero.
Old Apr 23, 2026 | 10:45 AM
Euroman's Avatar
Euroman
I had this with my truck. Buy a set of levers, I think I got mine from RockAuto, and you can swap them around. YouTube has some really good videos on it. I have small hands and old eyes but it wasn’t too bad doing it under a magnifying light. Took an hour or so. Try not to lose the springs on the floor…
Old May 14, 2026 | 08:37 AM
flyboyike's Avatar
flyboyike
4wd Low
So, an update: it looks like the tailgate was swapped at some point. I ordered a new key-matched lock cylinder from ebay, installed together with a new camera-equipped handle assembly, and the tailgate now locks just peachily.
Thanks, everyone, for your responses.
Old May 16, 2026 | 12:08 PM
Kentucky F250's Avatar
Kentucky F250
5th Gear
Do you mind sharing the link fro the camera/handle assembly?
Old May 16, 2026 | 03:46 PM
flyboyike's Avatar
flyboyike
4wd Low
Gladly.
https://ebay.us/m/XZ9cRp
Calebmark
Mar 4, 2023 06:12 AM
El Chupacabra
Jan 28, 2022 11:35 AM
scuba413
Jan 3, 2018 10:07 PM
QwkTrip
2009 - 2014 F150
Jul 17, 2012 07:13 PM
