DPF Soot Load flex
Old Apr 20, 2026 | 09:04 PM
SooperBlue's Avatar
SooperBlue
4wd Low
DPF Soot Load flex
Returned from a long road trip hauling my trailer and almost at Regen. The Banks is new so I've no idea if this is typical or not. FWIW, I used a blend of Opti-Lubes XL and Boost.
Old Apr 20, 2026 | 09:43 PM
chadstickpoindexter's Avatar
chadstickpoindexter
When I am towing the soot load on the truck and the iDash hit 0! It’s awesome!
Old May 2, 2026 | 10:20 AM
powerboatr's Avatar
powerboatr
my dpf stays at zero
towing or 75mph
but if we git caught in a few miles of stop, gooo
slow stop
It climbs up pretty fast to 35
once the heat is gone, it takes a few miles to drop again
Old May 2, 2026 | 11:09 AM
Overkill2's Avatar
Overkill2
towing or 75mph
slow stop
I think that not only due to the fact of less EGR being used for these newer 6.7s with their upgraded PCM strategy, but also think that possibly the design of the DPFs may have improved as well.
Because that's just awesome with what you are experiencing with that new truck of yours...
Old May 2, 2026 | 12:32 PM
powerboatr's Avatar
powerboatr
egr reduction in the HO is a great easter egg, for sure
i agree the dpf technology has changed a good bit
my 21 took long long time at sustained highway speeds of 70 or more to do a passive regen
my 24 did a commanded one weds, it took less than 8 minutes to go from 20 to zero, right on time at near the 600 mile mark from last one, i think having a low soot load when it trips really makes a huge difference in the speed of cleaning.
at 65 mph
i can sense now , by a slight change in smell around the truck when it lights off
did i say i like this one alot,
i dont even look at other trucks any more
plus the bull dog likes the back seat area to lounge
Old May 2, 2026 | 01:38 PM
Overkill2's Avatar
Overkill2
at 65 mph
If I am not mistaken, I believe the 20 6.7 started with the reduced EGR strategy IIRC but I could be wrong here... but maybe they had reduced it further and the result is the increased DEF usage.
The big upgrade to the DPF system was the 9th injector of the 23 6.7s. I also meant that maybe the internal design of the DPF has possibly changed as well but who knows?
But no doubt directly injecting fuel in the DPF gets it hotter quicker to complete the active regens a lot faster and less miles...
You pulling anything for your truck to go 600 mile regen intervals?
Old May 10, 2026 | 02:58 PM
powerboatr's Avatar
powerboatr
just the boat and that get dpf up to 35 fast around the ramp and idling at the ramp, pulling up ramp
idling whilst we secure boat, drive about 6 miles home at under 50 and then idling putting her away
last week she only got to town once
Old May 10, 2026 | 08:14 PM
Overkill2's Avatar
Overkill2
I'm impressed... those new trucks just flat out work better emission wise than the older trucks... but they cost more so they should right?
Old May 12, 2026 | 12:53 PM
powerboatr's Avatar
powerboatr
you know it and yesterday i drove to town about 38 miles round trip
murphy was 3.95 for fuel
i have 224 dte...dont want to go give plasma to fill up
seriously have to fill up thrursday , mrs boatr and i have to go to the big city for my lunch, shopping, lowes, etc etc
get to run the toll road at 75 to 77 for 40 or so miles each way
truck loves those runs
Old May 12, 2026 | 07:25 PM
Wellibe's Avatar
Wellibe
Active Streak: 30 Days
I'd kill for some $3.95 diesel about now...just sayin.
Old May 12, 2026 | 09:06 PM
chadstickpoindexter
Same!
Old May 13, 2026 | 08:25 AM
Painted Horse's Avatar
Painted Horse
You will notice your DPFDIS is 497 miles. The 23+ truck seem to have some programming that does an active regen every 497 miles It only takes 10 minutes because of the reduced loads and the more efficient 9th injector. But it still does a regen EVERY 497 miles, Regardles of what the DPF load is.
Old May 13, 2026 | 09:01 AM
Overkill2's Avatar
Overkill2
Enjoy the ride... love driving mine on the highways... just stiff AF when I get out. Getting older sucks... but all good.
x3 on that $3.95 fuel....
Old May 15, 2026 | 11:01 AM
speakerfritz's Avatar
speakerfritz
probably saves SCR’s by not having to cook them….assuming 9th injector is in between SCR and DPF.
Old May 15, 2026 | 01:38 PM
Overkill2's Avatar
Overkill2
Yeah, I have no clue where the 9th injector is in relation to the SCR and particulate filter, but while this is but one, they can last a long time if the truck is used correctly to give the DPF the chance to go out that far.
Now that I am thinking about it, my buddy has a 2026 F350 6.7. I will have to get underneath it and get a pic to compare to mine for schitts and giggles...
This one was at 939k miles. And IIRC, it was replaced free of charge (but could be wrong) because Ford wanted to look at it...
