HELP Engine issues after build!
Old Apr 21, 2026 | 08:52 AM
gman1377's Avatar
gman1377
Trailering
Originally Posted by Hit Man X
Either the PCM has to be scaled for new injector size or that MAF meter. Tuning MAFs is weird, we used Pro M ones back in the stone age. There was another brand/style with different size sample tubes to deal with injector sizing.
Agreed, what heads did you buy? Ps also take a near impossible to find header now. I too would have seen if they actually sealed if ebay specials
From what I understand from talking with Fiveology racing, theres no need to scale the ecu in my application. I currently use a PMAS sensor from their website.
As for the heads and headers here's the ones that I used:
Heads: https://ebay.us/m/RGyutD
Headers: https://ebay.us/m/UjGkvx
(for anyone curious, you will have to modify your Y pipe slightly to get it to fit correctly. Plus the supplied mounting studs will not work)
I love my chinese ebay specials 😉
But maybe it bit me in the *** this time...
Old Apr 21, 2026 | 08:54 AM
gman1377's Avatar
gman1377
Trailering
Originally Posted by Scndsin
So many things....
This is a flat tappet cam & not a roller?
Don't know anything about Fiveology. Was there re-pinning involved?
Adding of injector wires?
No tuning, just plugged in & run?
Yep. Its a flat tappet.
Repinning the ECU was required as well as adding injector wires. They included very detailed and comprehensive instructions. Ive double and triple checked my work and I can verify that all the ECU wires are in the correct place.
Old Apr 21, 2026 | 09:22 AM
Dentside Lover's Avatar
Dentside Lover
Is your plugs properly gapped and are you sure the right mixture is happening? They can say it works but clearly its running lean.
Old Apr 21, 2026 | 09:26 AM
gman1377's Avatar
gman1377
Trailering
Yeah I gapped them all to 0.044 per the manufacturer spec
Old Apr 21, 2026 | 09:30 AM
90project5.0's Avatar
90project5.0
Do you have a piggyback tuner like Moates or Quarterhorse? If so, have you tried an autotune? Not sure if they use that or not.
Old Apr 21, 2026 | 10:07 AM
manicmechanic007's Avatar
manicmechanic007
One thing at a time
You've made so many mods and some of the parts may not be up to snuff
I'd start back at the timing and whether the computer is controlling it okay and set the base time once more
I'd get a DU 30C for the distributor and a new Ford Motorcraft ignition module for it
You might want to put some of it back to "stock" until you get the drivability sorted out
Old Apr 21, 2026 | 10:10 AM
1Butcher's Avatar
1Butcher
Originally Posted by gman1377
It is a fresh new build and the piston rings have not been broken in yet. Plus the engine inst usually up to operating temp as I run it only for a few minutes at a time.
I would squirt some oil in the bores and recheck the compression. Broken in or not, that is too low for my liking. If the compression is still that low, I think you got cam timing issues.
We have all been down this road before. We tend to believe, it's nothing we have caused. One thing for certain, if you did everything right and everything is working right, it would be running fine. So, start with thinking that there is something wrong. I would start with thinking 'What did I screw up?'. I would not trust someone over the phone/internet telling me the ECU is the right one. I would get a second opinion and find a wiring diagram to confirm that the wiring matches your computer.
Old Apr 21, 2026 | 10:12 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Very old way to do it. I did a FMS MAF conversion with a Pro-M mass air meter and 30# injectors when I replaced the worn out 302 with a FMS 392 about 30 years ago.
I chose 24# to increase the power ceiling. The ecu doesnt need a tune for NA 24# injectors, it just needs a MAF thats calibrated for those injectors.
I didnt choose the MAF specifically to expand my options for cams, mostly for its improvements to mpgs and more capabilities for power adders, which allowed me to use that cam.
I used generic gt40 "style" aluminum heads. That use rocker studs which allowed me to use roller rockers which needed to he properly preloaded
The emissions delete was performed by capping off all unused vacuum ports, wiring in line resistors where needed, and capping off the egr ports. The Smog pump is still in pace but acts as an idler pulley pretty much. I had done the emissions delete a while before the engine build and it gave me no issues so I don't suspect anything in that regard is causing issues.
That was the way to do it a long time ago. The stock 5.0L truck computer can still only compensate so much. Maybe you have already exceed what it can do? Back when I did my MAF conversion the Ford kit used a Mustang computer but I see you need the truck computer for the E4OD.
You didn’t need stud mounted rocker arms in order to use roller rockers. Back in 2017, I used Scorpion 1.72 roller rockers when I swapped cams and installed GT40 heads on the 302
It might not have turned on the check engine light but the computer is more than likely going to set codes from those resistors. The input from the EGR is a different value when it is open than when closed. There is no way for a resistor to do that.
Old Apr 21, 2026 | 10:39 AM
1Butcher's Avatar
1Butcher
I spent a few minutes playing with injector sizes and MAF sensors calibrated to those injectors. The ignition timing changes with engine load and with a 'tuned MAF sensor' the ignition timing is not close to being right. I had to pitch the aftermarket MAF sensor and installed the stock MAF sensor. To save time, I just lowered the fuel pressure so the larger injectors delivered less fuel. I dealt with this for a decade. Eventually, I did put in the stock 19lb injectors and jacked up the fuel pressure back to stock.
Maybe a slight change injector size does not effect the ignition timing to cause problems, but larger ones with the tuned MAF sensor does. I would not go that route unless I could change the stock tune [Tweecer/Quarterhorse].
Old Apr 21, 2026 | 11:17 AM
KULTULZ's Avatar
KULTULZ
They did not have any in stock ECU's at the time but I was in touch with Brian from Fiveology and I bought an approved junkyard ECU. I also replaced the capacitors in the ECU.
Then you need to have the OEM PCM (E4OD) re-flashed for your desired fuel trim and timing curve. You would also have the EMISS features modified/removed.
Old Apr 21, 2026 | 11:22 AM
90project5.0
I would imagine he could give the parameters and they send him a “close enough” tune to tweak.
Old Apr 21, 2026 | 11:03 PM
gman1377's Avatar
gman1377
Trailering
UPDATE
I was able to put a vacuum gauge on it again and it looks like im getting extremely low vacuum (0-5inhg) at lower rpms which leads me to believe I installed the cam incorrectly. Will update later when I'm able to pull the front cover and take a look.
Old Apr 22, 2026 | 05:57 AM
  #28
90project5.0
That or your valves aren’t closing completely. Hopefully, just the cam!
Old Apr 22, 2026 | 08:10 AM
  #29
Scndsin's Avatar
Scndsin
My guess is a cam lobe on an intake valve is been flattened. (no lift=no filling CC=lean burn=glowing manifolds)
If it were me, I'd put a dial gauge on a plate bolted to valve cover holes & check lift before trying to pull cam out.
If you find it, then you can just pull engine rather than fiddle-farting with pulling cam before doing the inevitable pull.
By the way, did you test the seal on these heads before install? (I.E., 120 psi compression)
Sorry dude, it's just looking like a cluster. Maybe you'll get lucky & the cam isn't flattened & the filter not full of metal.
Old Apr 22, 2026 | 09:53 AM
  #30
Hit Man X's Avatar
Hit Man X
Very old way to do it. I did a FMS MAF conversion with a Pro-M mass air meter and 30# injectors when I replaced the worn out 302 with a FMS 392 about 30 years ago..
Yep, FMS kit here with a Pro M MAF, bought at Summit. I still rock 19s as basic 302HO with all bolt ons.
Interesting point about the PCM used perhaps beyond its ability to compensate. Even the HO MAF ones reach a limit where they need to be dialed in to work well.
Too many variables, but it happens.
