General Questions
Old Apr 15, 2026 | 09:14 PM
JonBoy5419's Avatar
JonBoy5419
2nd Gear
General Questions
In a previous post, I introduced my '91 F150 with the infamous 300-6 4 speed manual needing a headgasket. After some teardown I found a crack in the block. So here we are some weeks later about to attempt my very first engine swap, however I had some questions.
The engine I'm swapping in, is from an auto truck and was mated to an E40D, I'm familiar enough with the process to know that I need to install a pilot bearing, and swap over/retrieve a new flywheel, clutch, and pressure plate. However, the pilot bearing I got from the parts store looks different than the one installed on the engine that was in the truck. Curious if anyone has a guide or some images to let me look at just to make sure I've got everything I need so I'm not making 500 trips to and from the parts store.
Thank you! Below is attached a photo of the truck since I didn't include any in the previous post.
Old Apr 16, 2026 | 02:58 PM
jas88's Avatar
jas88
Does your old engine have a bearing? Or a bushing?
Old Apr 16, 2026 | 04:12 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Good question.
Bob the Ford Guy
May 2, 2023 08:07 PM
rderrick121
Apr 2, 2022 02:19 PM
mytoolman
Feb 11, 2022 07:25 AM
Rembrant
Sep 8, 2021 06:13 PM
MT Cowgirl
Dec 29, 2011 09:55 PM
