Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Help decoding my VIN
Old Apr 9, 2026 | 04:59 PM
Learaviator's Avatar
Learaviator
Trailering
Hello, my F600 VIN plate is attached.
Thank you for any help. It does now have a 391 industrial engine.
Old Apr 10, 2026 | 12:15 AM
85e150's Avatar
85e150
You've had that truck for a while. Maybe you forgot???
https://www.ford-trucks.com/forums/1...l#post19147065
F61 = F600 2WD (gas).
E = 361 2V FT engine.
V = Kentucky Truck Assembly Plant.
P20882 = 1972. (May 1972 production)
180" Wheelbase.
M = Wimbledon White.
F617 = F600 2WD (gas), 20200 lbs. GVWR
4 8: 4 = Black Vinyl / 8 = 81A Standard Cab.
2 = Clark model 282V 5 Speed Direct.
F2C:
F2 = Eaton model 15201 Two Speed Rear Axle / 5.83/8.12 / 15,000 lbs. Rear Axle Capacity.
C = Ford 6,000 lbs. Capacity Front Axle.
20,200 lbs. Gross Vehicle Weight Rating.
182 net HP @ 3,800 RPM
75 = Phoenix AZ Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Apr 10, 2026 | 06:11 PM
Learaviator
Trailering
Well....I guess I did!! Thank You!!
Old Apr 10, 2026 | 06:20 PM
Learaviator
Trailering
I was using it as a water truck at my off grid place, but I built a new deck over water trailer, and now I am going to make it into a ramp truck and haul my 49 F1 to Ford truck shows. Going to install Battle Born brakes on it.
Old Apr 10, 2026 | 06:22 PM
Learaviator
Trailering
I sure did not remember getting that decoded before....oops....
Ranger-f250
Large Truck
Apr 12, 2025 12:20 AM
ymountainman
Large Truck
Aug 10, 2020 05:16 PM
ShockFox395
Large Truck
Dec 9, 2018 03:15 PM
TheOtherStyle
Large Truck
Oct 23, 2014 10:25 AM
