Please help
Old Apr 9, 2026 | 09:40 AM
Eddie-Blue95's Avatar
Eddie-Blue95
Please help
Need help figuring out what’s wrong with my truck. Speedometer and odometer randomly shut off and now it’s shifting really hard.
Old Apr 9, 2026 | 10:05 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first thing to do is to read the codes that are stored in the PCM.
Old Apr 9, 2026 | 01:41 PM
Dentside Lover's Avatar
Dentside Lover
Check codes and fluid. I wonder if you have a shift kit in her. Otherwise probably got some sticky solinods in it. That's what I'd think but probably should trust the former engineer lol. But check basics before going deep.
Old Apr 9, 2026 | 02:07 PM
rla2005's Avatar
rla2005
With the odometer/speedometer blank and not indicating speed, you will most likely get a code for missing or erratic VSS signal. That will trigger the hard/late shifts. There may be more codes, but at this point fix the obvious first.
My first step would be checking Fuse 8 and Fuse 18. They supply power to the PSOM.
For reference:
Old Apr 10, 2026 | 07:58 AM
1Butcher's Avatar
1Butcher
Building a good foundation is always a good idea. Check for codes and the fluid, but the problem is right in front of you. Get the speedo working. Grab the wiring diagram and your DVOM. Check the signals at the speed sensor and the signal coming out of the PSOM.
Mich6.0
Escape & Escape Hybrid
Nov 28, 2023 09:55 AM
ScorpionKing
54
Jan 12, 2021 11:37 PM
texasbound
Dec 28, 2012 09:09 AM
