Bleeding brakes.
Old Apr 7, 2026 | 10:25 AM
Rubiranch's Avatar
Rubiranch
Bleeding brakes.
I just saw this on FB and it looks pretty cool for those of us that don't have anyone to help us.
Orion Motor Tech 1 Pair Brake Bleeder Hose, Orion Motor Tech 1 Pair Brake Bleeder Hose,
Search for the one that will work the best for you.
Old Apr 7, 2026 | 11:13 AM
mac.motorworks's Avatar
mac.motorworks
I've seen those in use before (or something similar at least) and they work well, assuming that the bleeder nipple is good and the hose has a good grip onto it. I've had "self bleeder" kits where the tube is not as tight as is needed and it allows air to bleed back in. I think good tubing and bleeders are key to this.
thanks for sharing this though for sure
Old Apr 7, 2026 | 11:58 AM
Rubiranch's Avatar
Rubiranch
I worked in a Honda dealership and the techs flushed brake systems all the time.
They just put the hose into a gallon jug filled about 1/3 of the way and they knew how many pumps it took to bleed each wheel cylinder on every car they worked on.
Old Apr 8, 2026 | 04:33 AM
manicmechanic007's Avatar
manicmechanic007
My wife is my assistant Ruiranch, is not that your assistant in the photo?
I need to teach you guys the trick of drilling a hole in an old master cylinder cap (2 holes in the older dual reservoir caps)
That way you can use a bit of low pressure shop air to bleed the master cylinder and all 4 brakes with 1 man in 5 minutes
Same principle as using an old EIS or Snap-On pressurized fluid brake bleeder, without all the mess
Old Apr 8, 2026 | 07:47 AM
mac.motorworks
I have a pressure bulb the size of a big basketball which I fill with brake fluid. There's a brake fluid reservoir kit which has reservoir caps. The kit covers most reservoirs and has a quick disconnect line on it. The bulb gets charged to ~15 psi, the proper cap installed and you work your way around the vehicle. Works like a charm and as the bulb holds about 3 litres of fluid, is pretty efficient.
hunts318
Large Truck
Jan 5, 2025 08:53 AM
wrkhrs6
Large Truck
Dec 9, 2023 02:53 PM
Slyhuntr
All Things Towing
15
May 11, 2021 06:47 PM
catrct
Jul 10, 2016 08:15 AM
dynamic
13
Nov 21, 2001 09:38 PM
