No brakes
Old Jul 8, 2016 | 10:09 AM
catrct's Avatar
catrct
Question No brakes
I have a 1988 F150, i just replaced all the ball joints of had to remove brake calipers. I cannot get the brakes to pump up now that i have everything back together. Please help!!!!!!!
Old Jul 8, 2016 | 10:23 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Did you unhook the brake hose from the calipers?
If yes, you need to bleed the brakes.
-Enjoy
fh : )_~
Old Jul 8, 2016 | 05:20 PM
catrct's Avatar
catrct
i have tried bleeding the brakes however cannot get anything out of the bleed value. cannot get the brake pedal to pump up. i have bled brakes before but have never experience this before
Old Jul 9, 2016 | 12:54 AM
joey2fords's Avatar
joey2fords
are you saying that no fluid comes through the bleeder screw(s) when you try to bleed ?
Old Jul 9, 2016 | 05:00 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Sounds like the bleeder is clogged.
Old Jul 9, 2016 | 06:13 AM
bert cook's Avatar
bert cook
sounds like you need to start from scratch bench bleed the master cylinder then the rear wheel cylinders then the front calipers
Old Jul 9, 2016 | 06:55 PM
My4Fordtrucks
While that couldn't hurt, it believe it is unnecessary unless the master cylinder went dry while the calipers were disconnected.
Old Jul 9, 2016 | 08:04 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Common issue. remove the bleeder screw, dig all the dirt out of the passage. Don't forget the cross drilled passage at the bottom.
Still, I'm thinking master cylinder. Failure would be unrelated to the ball joint work, just bad timing.
Old Jul 10, 2016 | 08:15 AM
tjc transport's Avatar
tjc transport
i ain't rite
my bet is the master cylinder drained out while the calipers were disconnected.
Dennis Bloxham
Flathead V8 & Flathead 6
Oct 27, 2013 10:27 AM
BigBlockF350
56
Apr 2, 2013 05:55 PM
petelynch
Sep 28, 2007 05:26 PM
greythorn3
24
Dec 23, 2006 12:31 PM
paulieman
Dec 10, 2002 04:11 PM
