1977 f150 4x4 radius arms are bent downwards at the rear mounting brackets ,,was thinking to heat them with a torch and gently use my press to straighten them out ,, or since they became bent cold use the press to bend them back cold . need the forums knowledge on which way to go .. does any one in the aftermarket make radius arms that can be substituted for the stock radius arms.
