351w
Old Mar 31, 2026 | 04:07 PM
48ford///'s Avatar
48ford///
Trailering
Exclamation 351w
I have a stock 1979 F-150 2wd with a 302, my friend has a 351w he would like to sell me, what problems might I have if I do a swap??
Old Apr 1, 2026 | 08:09 AM
manicmechanic007's Avatar
manicmechanic007
Basically nothing, it will bolt right in
few things though
351 has a taller deck, which means you need his distributor too
The exhaust manifolds might be different depending on year
You will need to change the firing order if the 351 is a roller motor
Old Apr 1, 2026 | 08:56 AM
48ford///'s Avatar
48ford///
Trailering
thank you
kenny nunez's Avatar
kenny nunez
Is your transmission manual or automatic and what is the 351 from, manual or automatic.
You have to be sure of this to have the correct flywheel balance.
Old Apr 1, 2026 | 09:49 AM
Rubiranch's Avatar
Rubiranch
Back in the '70s my friend owned this 1970 302 Maverick.
When he "built" the 302 he used 351W heads.
He said they had a little bigger valve than the 302 heads and a bigger combustion chambers.
He bored the 302 and used TRW 12.5:1 forged racing pistons.
The larger combustion chambers and 12.5 pistons gave him 11.0:1 compression.
That was my dad's1972 Ranchero GT with the 351C 4V.
It ran pretty darn good back in the day.
Old Apr 1, 2026 | 12:11 PM
5851a's Avatar
5851a
The oil pan drain plug may end up in a position being hard to use.
Old Apr 1, 2026 | 12:53 PM
48ford///'s Avatar
48ford///
Trailering
both are automatics with c6
Old Apr 1, 2026 | 12:54 PM
48ford///'s Avatar
48ford///
Trailering
will check
Old Apr 1, 2026 | 12:55 PM
48ford///'s Avatar
48ford///
Trailering
nice
Louiesant
Apr 14, 2025 05:49 PM
86f-250
Dec 12, 2006 06:14 AM
71mopar383
Aug 3, 2005 03:41 PM
samwe
18
Jul 30, 2004 01:03 PM
BroncoRoadKill
1978 - 1996 Big Bronco
Mar 12, 2003 10:09 PM
