Sponsored by: Kumho
Brake Issue after swap
Old Mar 30, 2026 | 08:03 AM
TroyBlueFord's Avatar
TroyBlueFord
8th Gear
Question Brake Issue after swap
I replaced my pads and rotors and after about 5k miles the driver side rotor was scared and outer pad was gone metal to metal. I figured was bad Caliber so ordered new rotors, pads, and calibers and replaced did extend bleeds to ensure dirty fluid was removed from lines and new caliber.
I just noticed that the driver side rotor is showing metal to metal contact on the outer 1/2" of the rotor.
Any Ideas why the caliber not releasing and causing the pads to wear out faster?
2016 Ford F150 Larit 4x4 3.6L
Old Mar 30, 2026 | 10:46 AM
KULTULZ's Avatar
KULTULZ
WHAT ARE YOU WORKING ON?
Old Mar 30, 2026 | 10:55 AM
TroyBlueFord
8th Gear
2016 Ford F150 4x4 lariat 3.6L
Old Mar 30, 2026 | 11:28 AM
KULTULZ's Avatar
KULTULZ
SEE IF THIS HELPS - https://nrsbrakes.com/blogs/supporti...per-slide-pins
Old Mar 30, 2026 | 01:08 PM
TroyBlueFord
8th Gear
Thanks, I will check it out
stan'37
Nov 3, 2017 09:49 AM
M-S-G
Apr 13, 2015 10:16 PM
CraigK
Jul 29, 2012 03:16 AM
kevin.ford-trucks
Apr 29, 2010 12:22 AM
00excursion
Apr 20, 2010 12:28 PM
