Rusty Radius Arms
Rusty Radius Arms
Planned on replacing bushings until this was removed. Not having much luck finding used in better shape, at least online or locally.
After much time searching for anyone who might have fixed in forums, youtube, etc...not much luck either.
Anyone ever built up with weld and was successful in use? Concerned about adding stress, but no seeing many options.
'74 F-350 2WD
Are you a professionial welder with professionial welding equip? If you have a 110 V wire feed and are a hobby sport welder, that equip is not going to do it. But I bet any pro welding/fab shop or pro mobile welder with a 220 stick or wire feed could properly build and strengthen that back up to the required radius.
That is criticial a suspension part to NOT mess with on a none professionial welder level IMO. Also insp the raidus arm bushing frame mounted bracket holes for excessive wear. Great time to replace them, hope they are bolted on and not riveted on, if you have to repalce them.
https://www.ebay.com/itm/36440197133...BlBMUKy0rc2nZw
I would braze weld a sleeve over that rust
Yours is about the worst I've seen
We used to wrap them with electrical tape and reinstall new bushings
Yours is a little beyond that
I'd be welding (brass rod brazing)
Maybe I'd use thinwall pipe like conduit and fill the void with braze rod
Can it be repaired? Yes. But thats not the desireable/best solution. Be persistent contacting salvage yards in arid rust free climates. These surely aren't a high demand used part and shouldn't be terribly hard to find. I am not sure if an F-250 arm is same as 350. Maybe someone with parts book can post what is compatible. So find that out first, and then that helps focus your search.
The only way I'd weld it up and grind it back to round is if the budget is already blown and you must get truck on road now.
Edit. You aren't first one ot have this problem. Just found this
https://www.ford-trucks.com/forums/1...adius-arm.html
_pinocchio
16
Oct 30, 2025 03:32 PM
Firs
Mar 19, 2024 05:03 PM
Adrian Arnold
Jul 30, 2023 12:32 PM
SwedeinNorway
May 22, 2020 02:46 PM
