Fuel pump run time?
Old Mar 26, 2026 | 02:44 PM
mcgyver42's Avatar
mcgyver42
Fuel pump run time?
TLDR: Does your fuel pump run 20 seconds EVERY TIME? Or does it build up to a pressure and then stop sooner?
2001 F250 7.3 diesel, 210000 miles. As of Monday, after replacing the starter, it has begun to refuse to start. Mostly. Cranks and cranks, but won't catch.
When I replaced the starter I didn't properly disconnect the batteries, causing some momentary sparks. I then properly disconnected them and finished the job. So I may have mucked something up.
SOMETIMES it will start, see video attached. When it starts, it runs fine. No miss, idles, pulls like it should. Turn it off, it starts right up again.
Fuses all ok, no codes, dash lights work as normal. New fuel filter. RPM dial jumps while cranking, so CPS is ok.
I live in the desert and the two times I've gotten it to start, it seems to start when it gets hot enough. Maybe the glow plugs aren't working? Maybe the fuel bowl heater?
I noticed that the fuel pump runs when you turn it on for the full 20 seconds every time. I don't recall that being the case before, but I dunno.
I'm grasping at straws here.
File Type: mp4
Old Mar 26, 2026 | 03:34 PM
John in OkieLand's Avatar
John in OkieLand
the PCM commands it to run for ~20 seconds and IF the engine has not started, it times out.
that is normal.
the Fuel Bowl return excess fuel to the tank, that is normal also.
Old Mar 26, 2026 | 05:00 PM
mcgyver42's Avatar
mcgyver42
Normal fuel pump run time
Thanks John, that's what I was thinking. Just wanted someone to verify for me.
Old Mar 26, 2026 | 05:36 PM
Pikachu's Avatar
Pikachu
20 seconds at key on. Runs continuously while signal is detected from the CMP sensor. Times out after 20 seconds if CMP signal is lost, but shuts off immediately if the key is turned off.
Sam Ve
23
Feb 15, 2026 10:18 PM
redman84
Jan 1, 2014 07:52 PM
John Clugston
Sep 24, 2012 06:25 PM
KColds
18
Jul 30, 2011 04:02 PM
Coolarctic
Jun 15, 2009 09:31 PM
