High rpm
Old Mar 24, 2026 | 03:50 PM
Younkin09's Avatar
Younkin09
3rd Gear
High rpm
I am currently having issues with excessively high rpm. At start up they run up to 2200 and are at a steady 1100 while idleing. I changed the EGR sensor, idle position sensor, idle air control valve and see no broken and cracked vacuum lines.
Old Mar 24, 2026 | 04:29 PM
90project5.0's Avatar
90project5.0
You have a leak somewhere. It could be one or both intake gaskets, It could be any of the vacuum lines if you haven’t replaced them yet. Take a coke can and cut a 3” square. Place it between the throttle body and idle air controller. No change? Move it to between the EGR and intake. No change, look at the throttle bores in throttle body. Are they gummed up and not allowing the blades to fully close?
Old Mar 24, 2026 | 05:16 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Please stop replacing parts. Did you have engine off fault codes for those parts? Did they test as being bad?
Old Mar 25, 2026 | 12:58 AM
seschenburg's Avatar
seschenburg
It's not always mentioned, but the order is:
Check codes.
Reseat the connector for the suspect component(s). Spraying either contact cleaner or WD-40 into the pins and sockets to help clean any funk.
Clear codes and test drive.
Check codes.
Same code, test the component(s).
If the component tests good, leave it. The problem is elsewhere - grounds, component activation signal, other component, PCM capacitors (it's time for everyone to check these), etc.
If the component tests bad, swap in your spare (you do grab spare sensors and stuff when you go to the u-pull-it yard, right?), or order a Motorcraft replacement, if available.
Check codes.
Grab a beer and pat yourself on the back for another job well done, or start over with new code(s).
mr.fordneck
Oct 20, 2012 10:49 AM
94to98E350er
Feb 10, 2009 07:20 PM
Surf Fishn Truck
1978 - 1996 Big Bronco
Oct 25, 2008 08:03 AM
gekitch111
Mar 12, 2007 04:34 PM
lfernung
Jan 16, 2003 11:05 PM
