Sponsored by: Real Truck
View Poll Results: What year frame should i use to restore my 7.3L powerstroke
Use a 2015 Supercab Frame
0%
Use a 2010 frame
0%
Use 2012 frame
0%
Use 2014 frame
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
1999 7.3L Supercab
Old Mar 23, 2026 | 12:36 AM
LexxiStarr's Avatar
LexxiStarr
4wd Low
1999 7.3L Supercab
I reccently aquired a 1999 7.3 Power Stroke frame a bit rusty, Engine need to be looked at may Require a rebuild . My question is, can i use a newer 2 door Supercab (2012-2016) to Swap frames with or would it not work? Because i just want replace the Frame
also when i decide to rebuild engine any upgrades i should do. i want to use a newer F250/F350 because i want to be rids of Front leave springs and go to Springs
Old Mar 23, 2026 | 02:12 PM
GN1220's Avatar
GN1220
Ford switched from leaf springs to coil springs in the 2005 model year. I think anything from 2005-2016 would work if you are just using the frame. Motor and transmission mounts might need some moving around, among other items.
Old Mar 23, 2026 | 08:09 PM
LexxiStarr's Avatar
LexxiStarr
4wd Low
Im in canada and two places i Checked wanted 4500$ just for a Frame. I only Need a Donor Frame i dont care if i have to Go to the States to Pick it up . Is there any alternatives before i go that Route? I just want to be able save the Truck the most efficient and Quickest ,safest way possible. as it go centimental Value. I am looking for a Reputable Diesel Engine Rebuilder
Old Mar 24, 2026 | 11:59 AM
Vadis's Avatar
Vadis
The issue that you will have to deal with is the 08+ frames is that they dip down in front of the rad supports so you'll have to figure that out for bumper mounting. The cab mounts should be be the same through the years as the cabs didn't really drastically change until 17+. Same with the box. Another issue that comes up is if you attempt to use a different cab/box config i.e. regular cab/long box instead of a super cab short box, etc
Old Mar 24, 2026 | 04:30 PM
LexxiStarr's Avatar
LexxiStarr
4wd Low
i Plan to Use custom Bracket on a Replacement Frame to extend out the Bumper, i have a Short bed From a 08 F250 5.4L i plan on using as i am going to be stripping it for parts anyways. I will be using Short Box ,tires,rims,locking Hubs,Mirrors, going from 08 F250 Crew Cab
Old Mar 24, 2026 | 08:27 PM
Old and soft's Avatar
Old and soft
I can't quite read between the lines here. Is the frame toast, or just wanting to lose the leafs up front? Or both? You mentioned 08 parts, do you have a complete parts truck? You did mention buying a frame.
Old Mar 30, 2026 | 03:12 PM
LexxiStarr's Avatar
LexxiStarr
4wd Low
The frame on the My 99' 7.3 supercab is Very very Rusty. I am going to Try and Salvage as much as i can . I Currently am Driving a 2008 F250 Crew cab with the Horrid 5.4L . I'm planing on using the Bed,Mirrors,tires and rims ,Maybe the Dash off the F250.
bullnosecc83
Jun 25, 2023 08:58 PM
Lee73
Mar 7, 2022 07:34 PM
Josh3240
20
Jul 17, 2019 06:32 PM
Clayman302
Jan 10, 2014 06:26 PM
comet
Mar 26, 2003 09:43 PM
