Bed rails
Old Dec 10, 2003 | 08:33 AM
Diesel Daddy's Avatar
Diesel Daddy
Question Bed rails
I need some help to locate a nice set of Ford bed rails.
The kind I'm looking for are from Ford. You could buy them from Ford for the early 70's trucks thru mid 90's. I'll try to describe them:
1. Each side has a long rail that seems to be aluminum. It sits on three "pedestals" which are mounted in the stake holes in the bed.
2. The inboard side of each rail has a channel that typically has 3 or 4 sliding pieces that you can tie stuff to.
3. The rail sits on the middle pedestal and slides into each end where it is fastened.
4. The pedestals are chrome or aluminum color also.
Old Dec 11, 2003 | 08:52 AM
Diesel Daddy
Anyone?
Old Dec 11, 2003 | 09:51 AM
bond10's Avatar
bond10
have you tryed ebay, or your local junk yard.
Old May 27, 2008 | 02:03 AM
AerostarDad's Avatar
AerostarDad
Like this...
Old May 27, 2008 | 02:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by AerostarDad
Like this...
1969/72 F100/350
D0TZ-9932230-A .. Bed Rail Kit-8' Box (1969 is the first yr these are listed, and only for the 8' box).
1973/79 F100/350
D3TZ-9932230-B .. Bed Rail Kit-8' Box
D3TZ-9932230-C .. Bed Rail Kit-6 3/4" Box
1980/86 F100/350
E0TZ-9932230-A .. Bed Rail Kit-8' Box
E0TZ-9932230-B .. Bed Rail Kit-6 3/4" Box
1987/96 (and some 1997) F150/350
E7TZ-9932230-A .. Bed Rail Kit-8' Box
E7TZ-9932230-B .. Bed Rail Kit-6 3/4" Box
NOTE: These are also listed for 1997 and later. There are at least 6 different types (Bright-Black-Aluminum finish). Ask me for a specific type, I'll post the part numbers.
I can also search via the internet, ALL the US Ford dealers parts inventories for a specific type that may be OBSOLETE, or not. I can also search obsolete Ford parts sellers sites.
Thank you for posting this illustration.
AFAIK, you are the only member on this site that can post illustrations from the 1973/79 Ford Light Truck Parts Catalog.
I can't because I'm using this catalog (and all the others from 1980 up) on FoMoCo microfiche slides.
Old May 27, 2008 | 04:26 AM
AerostarDad
Bill...you're welcome on the illustration posting. I would think anyone with a scanner and a paper parts book could post them as well.
You mentioned you can search dealer inventories for parts? I have a set of these bed rails, but are missing some of the plastic "pads" or gaskets that go between the supports and the bed rail itself. Any way of finding if there are any available anywhere?
Thanks,
Darwin
Old May 27, 2008 | 04:31 AM
NumberDummy
Thanks,
Darwin
The 73/79 parts catalog: there are at least 3 other ppl that have the CD scanned version here on FTE, but AFAIK, none have posted any illustrations from it.
Searching for parts (obsolete or otherwise) for ppl here on FTE is SOP for me.
Which rails do you have, the 1973/79 variety?
2) D3TZ9932242A .. Pad / Right front & Left rear.
2) D3TZ9932242B .. Pad / Right rear & Left front
2) D3TZ9932244A .. Pad-Center
> > Found them ALL on the first try.
greensalescompany.com has 19) D3TZ9932242A's / 7) D3TZ9932242B's & 20) D3TZ9932244A's.
greensales: located in Cincinnati, Ohio: 800-543-4959 / US phone number: 1-513-731-3304 / M-F ~ 8-5 ~ EDT
Old May 27, 2008 | 04:34 AM
AerostarDad
Bill, yes...73-79 version. I'm missing the left, front end one and both center ones.
Thanks,
Old May 27, 2008 | 04:51 AM
NumberDummy
Bill, yes...73-79 version. I'm missing the left, front end one and both center ones.Thanks,
That didn't take long...I wish they all were this EZ!
Found them all...see post #7 above....
Old May 27, 2008 | 11:18 AM
AerostarDad
Bill...thank you very much. I have an email into them now.
Old May 27, 2008 | 11:33 AM
LARIAT 85's Avatar
LARIAT 85
Dennis Carpenter also has these bed rails listed. They have a set for short box and another for long box trucks. The only thing is, they list the same rails shown in the above illustration for all 1973 - 1989 applications. Does anyone know if there is any difference to the numbers NumberDummy gave? What I mean is, is the newer part numbers from Ford just newer part numbers that superseded the older numbers, or did Ford actually change the rails over the years? I noticed that the ones on my 1985 F150 look exactly like the ones that are on a 1987 model.
Old Dec 11, 2015 | 10:24 PM
mic91F150's Avatar
mic91F150
any updated info on these Factory bed rails....Im looking for a set.
Old Dec 11, 2015 | 10:38 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Dennis Carpenter is reproducing them now.
www.dennis-carpenter.com
Here's a link to the bed rails:
http://dennis-carpenter.com/bed-top-...3TZ-9932230-B/
Old Dec 12, 2015 | 07:37 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Oh you mean these? I have a couple of OEM sets.....and they even have the plastic ***** that loosen up and slide adjust back and forth in the back side of the rail.
mic91F150 build up your post count to 25 then you can make and receive PM's (private messages are how sales are conducted on here and not in open forum).
Ck your visitor message box.
Old Dec 12, 2015 | 09:53 AM
mic91F150's Avatar
mic91F150
Top Side Bed Rail Kit | Dennis Carpenter Ford Restoration Parts
thank you Mike!
