Radiator
Old Mar 21, 2026 | 12:39 PM
Mtncatnip's Avatar
Mtncatnip
7th Gear
Radiator
Hi all
94 f150 5.0 recently had a new radiator installed and was checking the coolant level to see if it was staying full . Topped it off a couple weeks ago and have not driven it since but when I turned the radiator cap coolant sprayed out . What could be causing this on a cold engine . Thanks!
Old Mar 21, 2026 | 12:45 PM
90project5.0's Avatar
90project5.0
To clarify, you topped it off and haven’t turned it on since? Just before you opened the cap this time, had it been running at all?
Old Mar 21, 2026 | 01:05 PM
Mtncatnip's Avatar
Mtncatnip
7th Gear
I did start it briefly to move it about a week ago but that’s it
Old Mar 21, 2026 | 02:47 PM
My93F250NH's Avatar
My93F250NH
I would start by verifying the radiator cap is the correct pressure rating and is functioning properly. A faulty cap can trap pressure instead of venting it to the overflow reservoir. Also check that the overflow hose and reservoir are clear and not blocked.
Since the radiator was recently replaced, trapped air in the cooling system is another very common cause. Air pockets can expand and create pressure even on a cold engine if the system wasn’t properly burped.
Old Mar 21, 2026 | 03:38 PM
Mtncatnip's Avatar
Mtncatnip
7th Gear
I was thinking it might be air. I parked it on a hill and squeezed the top hose until I didn’t see any bubbles.The level dropped some and after running for a few min I removed the cap and didn’t have any issues
Old Mar 21, 2026 | 04:00 PM
My93F250NH's Avatar
My93F250NH
Cool, happy to hear it's fixed!
Old Mar 21, 2026 | 04:59 PM
Mtncatnip's Avatar
Mtncatnip
7th Gear
Thank you !
Old Mar 22, 2026 | 04:09 AM
manicmechanic007's Avatar
manicmechanic007
Head gasket issue?
Use a block dye test to verify
Run it cold with the radiator cap off, look for bubbles
Old Mar 22, 2026 | 09:51 AM
HydroDog's Avatar
HydroDog
What was the temperature when you filled it and what was the temperature when you checked it?
JoePa2
2014+ Transit
Mar 14, 2024 06:15 PM
eenyok
Feb 2, 2023 05:25 PM
Ryan05KR
Mar 3, 2021 12:07 AM
Wayne Waldrep
61
Apr 11, 2014 06:37 PM
gumboluvr
May 29, 2007 06:23 AM
