Ticking / knocking when cold under load
Old Mar 15, 2026 | 02:47 PM
bremen242's Avatar
bremen242
Hi all—
I have a 2016 F150 with a 5.0 Coyote. It has about 165k miles on it. It’s been a good truck.
Lately, I’ve noticed under light acceleration when the truck is cold, it will have a tapping/knocking sound driving under light load. This seems to go away when it is up to temperature. If I leave off the gas, the noise goes away, instantly.
I am guessing that it could be piston slap. However, I know the timing tensioners can be an issue. I’ve search around, and most problems are referring to new motors
thanks
Old Mar 17, 2026 | 09:47 AM
GlueGuy's Avatar
GlueGuy
Originally Posted by bremen242
Hi all—
thanks
Could be pre-detonation. There are knock sensors that are supposed to detect and correct for this which may be malfunctioning. Try a load of premium fuel to see if it fixes it.
Old Mar 19, 2026 | 10:41 AM
JPG37's Avatar
JPG37
Sounds like a leaking exhaust manifold gasket, as it heats up it expands sealing the leak, just a hunch.
Old Mar 19, 2026 | 06:11 PM
bremen242's Avatar
bremen242
I filled up with E15 last night. I’ll see if that helps.
that also gives me an idea to check the data pids for a alcohol content. It is a flex fuel model— chevies get stuck sometimes, and I’ve been running 87 in it most of the winter.
Old Mar 19, 2026 | 06:13 PM
bremen242's Avatar
bremen242
that’s a good idea. My 351 used to do that. I’ll give it a look. Hopefully it is better than changing exhaust manifolds on a 5.4L jellybean.
Pool Runner
2009 - 2014 F150
Feb 10, 2026 06:35 AM
mds1870
3.8 & 4.2L V6
21
Sep 7, 2020 05:04 PM
Fordidipower
Apr 8, 2013 04:33 PM
armynavyguy
Modular V10 (6.8l)
18
Jan 29, 2008 04:15 AM
60f100trk
1983 - 2012 Ranger & B-Series
Nov 29, 2004 01:02 AM
