Stalling issue
Old Mar 6, 2026 | 05:12 PM
Norton manx's Avatar
Norton manx
5th Gear
Stalling issue
Hello I have a 1996 F-250 with a 460 engine that stalls when throttle is slightly pushed and allowed to return. Revs up fine and idles fine. Seem to catch it self sometimes and continue to run. Weird thing is if I remove TPS from throttle body and still plugged into harness the stall problem goes away. Any help would be greatly appreciated. Thank you
Old Mar 7, 2026 | 04:11 AM
charlie g's Avatar
charlie g
FTE Community Team
welcome to FTE i have made a thread of your own here https://www.ford-trucks.com/forums/1...ing-issue.html please fill the members in with more inforamtion
Old Mar 7, 2026 | 02:13 PM
Beechkid's Avatar
Beechkid
Test the TPS but also clean your throttle body if you haven't already.
Old Mar 14, 2026 | 12:22 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
If the throttle body is clean, I'd suspect the IAC valve next. You might want to check out the Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) forum. They can help you out over there!
Welcome aboard!
ASP64
Jul 10, 2024 03:10 PM
tupapimija
New Member Introductions
Jul 16, 2022 11:38 PM
bompa
Oct 30, 2021 10:39 PM
anderson123
Jul 18, 2016 04:15 PM
john-h_schmidt
Jan 28, 2007 03:26 PM
