91 F150
Old Dec 9, 2003 | 10:49 PM
glennwarren's Avatar
glennwarren
91 F150
Hello. I am new here and glad to meet ya'll.
I have a strange problem and was hoping someone may be able to confirm my suspicion or point me in the right direction.
The oil pressure in my 91 F150 has slowly but surely over the last couple of years gone from on the R in the word on the gauge to below the letter N. It doesnt smoke or burn oil or anything like that. Could someone tell me their initial opinion?
Old Dec 9, 2003 | 11:49 PM
f100guy's Avatar
f100guy
bad main bearings. how many miles is on this truck
Old Dec 10, 2003 | 08:28 AM
glennwarren
it is like 175,000 miles. If you dont mind, how would the main bearings do that?
Old Dec 10, 2003 | 08:37 AM
gatesj's Avatar
gatesj
Sorry everyone if I'm starting to sound like a broken record with the oil pressure gauge thing....
Beginning in 1990, Ford started putting a switch in the block instead of a variable sensor, and wired a resistor inline with the oil pressure gauge. The effect is that the gauge shows nothing for under 6-8 psi. Then the switch triggers over that level and the gauge immediately goes up to just over halfway.
Now, you or someone else could have pulled the cluster, soldered across the resistor and replaced the sensor with the bigger bell shaped one.
First look at the sensor, it's just toward the back of the truck from the oil filter. If it's just under an inch across, it's the switch and the reading is bogus.
Why it would read lower if it's the stock '91 setup, I'm not sure, but it would have to be an electrical thing...
Put a mechanical gauge on it to confirm what's going on before you do anything.
Old Dec 10, 2003 | 10:26 AM
MustangGT221's Avatar
MustangGT221
Over time the bearings wear out inside the engine and the gaps cause pressure loss. The way to tell is that the pressure is good when the engine is cold, but drops when the engine warms up. This is because the oil thins out when it's warmer. Get a gauge and check to see what the engine is actually doing, then go from there.
Old Dec 10, 2003 | 10:28 AM
MustangGT221
Moved to engine forum.
Cabinetmakermm
16
Apr 20, 2011 07:58 AM
ac700wildcat
15
May 14, 2010 04:17 AM
berndog91
Aug 18, 2009 12:25 PM
LS1 Powered
Mar 4, 2005 08:31 PM
HD
Aug 4, 2001 05:53 PM
