Inner Structure Paint?
Old Mar 4, 2026 | 01:29 PM
Bronco912's Avatar
Bronco912
I bought a new hood for my '83 Bronco. It's from NPD. I'm wondering if there's a product I can spray inside the inner structure frame holes of the hood? Something to protect it from corroding in the future. The hood is gonna get primer and paint on both sides.
Old Mar 6, 2026 | 05:45 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Just shoot everything with primer and paint. To help reach scuff it up inside the holes, get everything you can reach with a maroon scruff pad and use a rod to push it around to scruff up as far as you can reach. When you start to spray, start with spraying inside each hole so the overspray is on the underside of the hood, and then shoot the hood, covering up all the overspray. You don't need a devoted product. 2k primer and 2k paint will protect it for years, just as it will the two main outer sides.
Bigblue#2
Sep 6, 2021 12:25 PM
SouthernBlues
Paint & Bodywork
Jan 25, 2009 08:06 PM
bradshaw6243
Paint & Bodywork
Jun 30, 2007 06:21 PM
apropos
General Automotive Discussion
Jun 27, 2007 05:19 PM
jsmoluk
Oct 8, 2002 12:21 PM
