hello team,
So I have a 2003 Ford Harley Davidson truck and I also have a 2005 Ford F150 lariat edition. My question to you guys is would it be possible to transfer 03 Ford F150 Harley Davidson truck motor engine and tranny 205 Ford F150 edition What custom changes would I have to make and what would I have to modify for it to be possible for it to work can you guys help me out please? Thoughts feedback I would appreciate it. Thank you so much.
I think we need a bit more information:
What engine & trans is currently in each truck?
Is either truck a 4X4?
Some things to think about:
The electronics in each truck is probably quite different. All engine and trans electronics will have to be transferred with its associated engine to the receiving truck. And made to work.
If you live in a state that does emissions testing, that could be a problem putting an '03 engine in an '05 truck.
What's wrong with the engine in the 2005? Would it be better to rebuild the '05 engine or install a re manufactured engine?
I moved you here as the truck getting the engine is the '05. As indicated above, there may be quite a few differences.
This site divides the F150 '97 to '03, then '04 to '08 which signals some major changes and as in almost every case with newer stuff, not just appearance.
What is the condition of the '03? Might be worth more as a running truck than a proper engine for the '05.
If you need to smog the 05, the 03 engine will never pass. The transmissions are different before 04, 04-08, after that are different also. 05 computer will not run the 2 valve engine, missing variable cam timing on the 2 valve and probably EGR on the two valve. Rebuild the 05 if you want that truck, sell the HD 03 to finance the project.
