4.2L timing cover replacement. Gasket or RTV on the bottom?
Old Mar 2, 2026 | 10:22 AM
awhtx's Avatar
awhtx
I'm replacing the timing cover on a 2003 4.2L. Is there a gasket between the oil pan and the cover or do you put a bead of RTV there? If you use a bead of RTV how do you keep it in place while you install the cover? If you slide the cover into place with the long studs screwed into the block it looks to me like you will smear the RTV off of the pan. So do you remove the studs before you install the cover? I've looked at all of the youtube videos regarding timing chain replacement and none of them show how to reinstall the cover.
Old Mar 3, 2026 | 08:53 AM
70f100longbed's Avatar
70f100longbed
It uses RTV. Make sure all oil is cleaned off. RTV doesn't seal against oil. I normally place the bead along the front edge of the oil pan and installing the timing cover pushes the RTV into place.
Old Mar 3, 2026 | 08:59 PM
awhtx's Avatar
awhtx
Thanks. I went ahead and removed the 4 studs so I could raise the cover up as I slid it over the crank snout.
0500757Arf
May 15, 2016 11:27 AM
lee00
May 2, 2016 02:06 PM
jimbo285
Aug 22, 2012 06:08 AM
fox3698
Jun 20, 2011 05:40 PM
