7.5 timing cover replacement
Old Aug 22, 2012 | 12:09 AM
jimbo285's Avatar
jimbo285
Replacing broken timing cover and old water pump with new ones on 96F250 7.5l. Should I throw away the paper gasket that came with the timing cover and just use an RTV type sealant, or should i coat both sides of it with a bead of sealant? Decisions, decisions.
Old Aug 22, 2012 | 12:23 AM
Puddy's Avatar
Puddy
Id say get a New Gasket Set, and also do a Bead of RTV thin on both sides
Old Aug 22, 2012 | 06:08 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Use a new gasket.
Don't fill the convolute grooves in the cover with RTV.
They keep a failed water passage from filling your crankcase and give you a sign that something is wrong.
Mbizzal
22
Mar 11, 2019 11:33 AM
0500757Arf
May 15, 2016 11:27 AM
mike2112
Feb 19, 2009 11:08 AM
morepower16
Apr 25, 2003 09:26 PM
