Intermittent overheating
Old Feb 28, 2026 | 03:45 PM
Mexilent's Avatar
Mexilent
1st Gear
I am passing down my 2009 Ford F150 lariat to a new driver in the family!
issue I am having with it currently:
It tends to over heat in idle and coolant in the reservoir tends to get emptied. There is no leak when running or driving. When in open air the temp regulates to normal. Even when there is coolant in the reservoir it is
boiling hot! There is a small crack near the cap. Will replace the reservoir as soon as it comes in.
hopping to see if anyone has had the same issue or what I need to do to investigate the issue.
water pump and thermostat replaced less than a year ago.
fuse relays have been checked and in good order.
Old Feb 28, 2026 | 11:00 PM
steve(ill)'s Avatar
steve(ill)
the system is suppose to be under pressure... if the tank is cracked, your running atmospheric pressure only and it will boil.
VG05
Modular V10 (6.8l)
Apr 3, 2024 06:35 AM
VG05
Mar 31, 2024 05:54 AM
djed
13
Feb 12, 2023 07:16 PM
carloc
6.4L Power Stroke Diesel
Dec 18, 2020 05:34 PM
69ford99
1997 - 2003 F150
Jan 4, 2014 09:40 PM
