Pulling the 360 & c6 question
Old Feb 26, 2026 | 02:49 PM
whitey68's Avatar
whitey68
So which way is better with transmission stille connected, or unhook trans and pull them out separately???
Need some solid advise!
thanks man
Jeff
Old Feb 26, 2026 | 04:41 PM
blue68f100's Avatar
blue68f100
All depends if you got the room and enough height on the picker. I prefer to pull them together if I'm needing to get them both out. If you have the front clip off, pull them together.
Old Feb 26, 2026 | 05:13 PM
charlie g's Avatar
charlie g
FTE Community Team
we unbolt the convertor from the flex plate than pull together only issue blue 68 just outlined height of your picker
Old Feb 26, 2026 | 10:35 PM
1browski's Avatar
1browski
I dont have a big azz cherry picker, so I just pull the engine and drop the tranny out the bottom. For what reason are you pulling them out? If your rebuilding them, I would just pull them separately. That way it can go right to the engine stand.
Old Feb 27, 2026 | 08:34 AM
manicmechanic007's Avatar
manicmechanic007
If by yourself, and without a well equipped shop, it's easier and safer to pull the trans out first
That's a YUGE hump you gotta go over where the radiator support will not bolt out
Old Feb 27, 2026 | 09:17 AM
fe390pc's Avatar
fe390pc
I would pull the engine and trans together, but I would also pull the core support before. Just my method as its a lot easier when you are doing it alone with a cherry picker. Also if you pull the core support, you can leave the hood on. Just my way of doing it.
Old Feb 27, 2026 | 04:52 PM
Crop Duster's Avatar
Crop Duster
If you pull a C6 from the bottom you will have to remove the center cross member. The bell housing is to large to clear.
Old Feb 28, 2026 | 04:50 AM
Crop Duster
Sorry @fe390pc didn't mean to quote you I was on my phone, I hate phones.
This has been my experience with C6's in these old trucks. In 65 and 66 and maybe 67 if the truck came with a standard transmission the center crossmember was riveted in if it came with an automatic it was bolted in. Possibly by 69 they were all bolted I don't know for sure. Even if it is bolted in removing it isn't easy and reinstalling it is even more difficult. If you don't have a 4-post lift getting that crossmember back in is almost an exercise in futility. On the last and only C6 I will ever remove from the bottom we had to make a spreader with a piece of pipe and all-thread to spread the frame rails enough to re-install the thing.
@whitey68 Buy or borrow a heavy-duty hoist and a load leveler what you are dealing with weighs over 800 lbs. If things go wrong, it can knock the bark off of you and or your truck.
Old Mar 1, 2026 | 11:08 AM
fe390pc's Avatar
fe390pc
No worries Crop Duster. I just think it's easier to pull together for the reason you stated.
Old Mar 3, 2026 | 09:45 PM
whitey68's Avatar
whitey68
She's out
Got the them out and on the floor. I cannot find a casting number on this pig any where, I mean no place on the external of the block at all.
just has the normal 352 on the front but on the back of the block it has 66 427 does this mean anything?
Old Mar 4, 2026 | 08:54 PM
Coastal68's Avatar
Coastal68
https://www.diyford.com/how-to-ident...ord-big-block/
Old Mar 6, 2026 | 10:05 PM
whitey68's Avatar
whitey68
So I still haven't found any casting number, and I looked up where to check.
I found the casting date Aug 30 1968
from the flint foundry
casting number on the head and a number on the crank.
Old Mar 7, 2026 | 04:12 AM
Crop Duster
It appears someone has been in that engine since it has a double roller timing chain. The casting numbers should be on the right (passenger side) of the block somewhere, but like the head casting they won't tell you much since Ford used the same castings on different engines. Your engine isn't a 427 since it doesn't have cross bolted mains. The only sure way to tell what you have is pull the heads and measure the bore and stroke.
Old Mar 7, 2026 | 02:22 PM
whitey68's Avatar
whitey68
Yeah I'm positive it's not a 427, I have to measure the stroke like you said to see what it is.
The pistons have valve reliefs in them, I pulled two main caps and two rod caps and the bearings looked like the were put in yesterday.
it leaked oil like crazy, oil pan bolt were cranked down, all of them just torqued down. The intale leake at both china walls, had gaskets and gobs of permatex.
timing cover like pan, bolts cranked down, valve covers finger tight.
The good thing is they used all felpro gaskets 🫡, and about 4 tubes of a white permatex like substance 🙄
funny thing, the cam plug was leaking, its installed right looks to have permatex on it , i would have used indian head. one of the core plugs is leaking for the same reason.
FordBronco1978
15
May 31, 2025 03:39 PM
rick314159
Nov 3, 2024 09:01 AM
Mythic
Ford Truck Parts for Sale
Oct 24, 2011 08:09 PM
jaye
Sep 27, 2008 07:57 PM
HICKEY
Oct 20, 2004 06:49 PM
