Crank no start solution
Old Feb 23, 2026 | 11:28 AM
Cardriver333's Avatar
Cardriver333
2013 f150 5.0. Cranks, doesn't start. I swapped fuse 27 and fuel pump relay with no change.
Ended up doing research and found out about the fuel pump control module. If it gets wet it stops working, so it is conveniently located above the rear axle.
duralast module 20987 $74 at autozone. Unplug old one, plug in new one. Truck started right up.
I know this is an issue that has already been discussed, but I wanted to put out some info to hopefully save someone else from this headache.
Old Feb 26, 2026 | 07:14 PM
wirelessengineer's Avatar
wirelessengineer
That's a bit of an overstatement. The early ones had an aluminum body, bolted to a steel frame member. This caused corrosion. It was NOT just a matter of getting wet.
I just bought one for my 2011 and in my shopping, all of them I found have a plastic body.
Old Feb 26, 2026 | 10:07 PM
HomerWinzlow's Avatar
HomerWinzlow
If it fixed your truck, great job! These arent nearly as common an issue as the GEN 11 trucks but they still can fail.
Skipper 7886
Aug 16, 2024 08:14 AM
86_cookiemonster
2009 - 2014 F150
May 9, 2022 02:17 PM
mikren
2009 - 2014 F150
Jan 25, 2022 06:57 PM
nlassley
2009 - 2014 F150
17
Dec 28, 2021 08:59 AM
makuloco2000
2004 - 2008 F150
Jan 16, 2014 12:00 AM
