Another BAT listing...
Old Feb 15, 2026 | 10:08 AM
Iowa Mike's Avatar
Iowa Mike
Here's another BAT F100 that's a bit better than the last one.
1961 Ford F-100-Bodied 2009 Ford Crown Victoria Police Interceptor for sale on BaT Auctions - ending February 21 (Lot #230,886) | Bring a Trailer
It's got it's flaws but I like it.
Old Feb 15, 2026 | 01:43 PM
TA455HO's Avatar
TA455HO
Lead Gopher
The gauge panel could probably be integrated a bit better into the dash. Short bed BBW unibody. Rare truck!!
Old Feb 15, 2026 | 05:36 PM
FarmMotorSports's Avatar
FarmMotorSports
Wow, another pig in a poke build.... Don't bother to remove the curl in the bed sides just in front of the rear wheel openings. ( From lifting the body with a post lift) Tack a square tube between the rear frame rails, and tack the rear bumper to that.... Open hole in fire wall where master cyl was. Finishing the build would be a major project... The under side picks reveal, tack welds holding everything together.... Just sad... Wiring dragging on the driveshaft.... Just wow.
Ha ha, mis drill the filler hole in the bed? Tack the metal plug back in and smear some bondo over it, don't sand it, just paint over it!
Old Feb 15, 2026 | 05:56 PM
Iowa Mike's Avatar
Iowa Mike
Yeah that instrument panel and hole in the firewall are real head scratchers. Makes you wonder what other hidden surprises there are besides what @FarmMotorSports pointed out. I'd still buy it for the right price.
Old Feb 15, 2026 | 06:01 PM
Nevada51's Avatar
Nevada51
"Probably"!
Definitely a rare truck bit a bit of a shame to see it like this for all the reasons mentioned above....and more!
Old Feb 15, 2026 | 06:05 PM
Iowa Mike's Avatar
Iowa Mike
Originally Posted by Nevada51
"Probably"!
Yeah if it had been executed better it wouldn't be so bad but personally I woulda restored it instead of butchering it.
Old Feb 15, 2026 | 06:16 PM
FarmMotorSports
Oh Yea, Bring An Enclosed Trailer, so you don't loose any parts on the way home! The more under side pictures I examined the worse it gets! Floor rust some with panel bond leaking out some not... Steering shaft u joints welded to ground down shaft...
Old Feb 15, 2026 | 06:53 PM
skidoorulz's Avatar
skidoorulz
Speechless. That instrument cluster looks like a cluster
Old Feb 15, 2026 | 07:10 PM
FarmMotorSports
I believe the cluster was installed just like the rest of the build.
Old Feb 15, 2026 | 09:47 PM
PROSTOCK's Avatar
PROSTOCK
In theory, it's a cool idea, and I actually like the looks. So I assume they set out to prove it could be done and found out.
Old Feb 15, 2026 | 11:17 PM
rusty valley's Avatar
rusty valley
Better than the last one? I strongly disagree with that. This thing is a wreck. Close ups of the hood look like a deep pitted rusty old hood with red paint sprayed on yesterday. Cargo tie downs, yet all the cargo space is gone due to the "raised diamond plate floor" ....for what?
Bidding is at 2500 now, thats where it should stop IMHO. What a shame that rare truck fell into the wrong hands
Old Feb 16, 2026 | 07:56 AM
AZSCAWPION's Avatar
AZSCAWPION
Curious as to what you think makes it better than the last one. Aside from the fact that the previous owner took a bath on that one, it was mostly original and unmolested. This thing's a ticking time bomb with little time left on the clock. Would've been worth more if they left it original. What's the right price for you?
I've seen lipstick on a pig before but most don't apply it with a roller.
Old Feb 16, 2026 | 08:03 AM
Iowa Mike's Avatar
Iowa Mike
Originally Posted by AZSCAWPION
Curious as to what you think makes it better than the last one. Aside from the fact that the previous owner took a bath on that one, it was mostly original and unmolested. This thing's a ticking time bomb. Would've been worth more if they left it original.
Personally I like it better than the last BAT truck but it's definitely not for everyone. I love the year and body style (I do not like step sides), I like the Crown Vic swap, and the original truck seems fairly solid. If the price is right and it's closer to me I'd buy it and fix the flaws. I'm retired, I've got plenty of time.
Old Feb 16, 2026 | 08:56 AM
PROSTOCK's Avatar
PROSTOCK
LOL!
captradiator
May 9, 2010 05:30 AM
Red Ford Truck
Ontario Chapter
Mar 13, 2010 07:54 PM
