lug nut size
Old Feb 7, 2026 | 07:58 PM
56panelford's Avatar
56panelford
lug nut size
Several years ago I picked up a 1996 F350 2wd dual rear wheel cab and chassis that I'm using for a project and the front wheels had lug nuts that take a 7/8" socket where the rear wheels had lug nut that take a 1 1/16" socket..
which nuts would be correct ..?
Old Feb 7, 2026 | 09:06 PM
Last chance 53's Avatar
Last chance 53
I have owned several 80-90"s F350"s and they all had 1 1/16'' lugs. The dually nuts should have a washer on them.
Old Feb 7, 2026 | 09:17 PM
56panelford
All these nuts have the washer, I want them all the same on the truck and just wanted to know which ones I should match up.. I figured the dually's had the larger size . This truck was in an accident and they put a cab from a 95 single rear wheel axle and was thinking that was where the smaller nuts came from. Thanks..
Old Feb 8, 2026 | 03:51 AM
manicmechanic007's Avatar
manicmechanic007
The smaller nuts just save weight
Yours should have had the 7/8 from the factory IIRR
Use whichever ones you want
JohnyChevyEG
May 30, 2024 09:50 AM
BlueOvalBud
41
Mar 4, 2024 08:56 PM
jake415
2015 - 2020 F150
21
Jan 7, 2022 05:47 PM
skyfox10
17
Oct 24, 2013 04:00 AM
huse
Mar 19, 2010 04:58 PM
