loss fuel
Old Dec 9, 2003 | 04:06 PM
DarkMaster's Avatar
DarkMaster
Unhappy loss fuel
I have a 90 250 and the glow plug relay is fried so in the morring i have to remove my air filter and manaul turn on my gloplugs i was doing that tyoday and i saw fuel on the manafold below the injections i satrted the truck and looked for a fuel drop but could not see one i shut it down and looked for 5 mins still didnt find a drop started it back up and drove around when i stopped i had a drip slow drip coming for the passager side of the fan area got under the truck and the hole truck is wet with what i dont know it smells like fuel but i can find the problem this is my only truck right know and cant risk sending to shop to find the problem anyone got any ideas
Thanks
Old Dec 9, 2003 | 04:14 PM
redneckmechnic's Avatar
redneckmechnic
bet its yar return lines or the o rings on the leak off caps that go to the injectors. they tend to get dry and hard and then if they get bumped by somthing or someone they leak. starts slow at first then gets real bad or atleast thats what mine did. It took me about 45 minutes to put on all new leak off caps o rings and return lines. just make sure ya get the rite size o rings and ya need 2 for each cylinder. good luck
Old Dec 10, 2003 | 05:44 AM
pnose's Avatar
pnose
Check the line from the lift pump up to your fuel filter,it may have rubbed off something causing a small hole or may be leaking at the filter connection and running down the line.
Old Dec 10, 2003 | 09:09 AM
bilder12's Avatar
bilder12
You may also want to check the weep hole in the bottom of the injection pump. It is a real bugger to get to , but you get you finger under the neck of the pump housing right behind the mounting flange. It is important to use an additive to lube the seals in the pump.
Old Dec 10, 2003 | 05:06 PM
DarkMaster's Avatar
DarkMaster
filter is fine it as to do with th metal lines behind the oil cap and the think there in I checked all the lines but can not see anything the licks so slow i can fine it. it takes about 6 hours to get any fuel the u can see but i just cant find it also the fuel (or what ever it is) all over the front end its always wet. can find a hole anywere i have been looking for days now.
Old Dec 11, 2003 | 12:33 PM
bilder12's Avatar
bilder12
When you say the front end is always wet ... where on the front end are you talking about? There is a lift pump ( like gasoline engines ) mounted on the passenger side of the engine that operates off a cam lobe. There is a weep hole on that pump that may be causing the wet spot on the lower front of the engine.
Old Dec 11, 2003 | 07:53 PM
DarkMaster's Avatar
DarkMaster
the pass side all over it from top to bottom im going to start tomorrow and look for what is doing it. i just dont what to look in the wrong place and spend alot of time in the wrong place.
Old Dec 13, 2003 | 09:00 AM
fonefiddy's Avatar
fonefiddy
Might wanna clean the bottom end first. Car wash?
kwztoy
Jun 30, 2013 07:18 AM
Tlizle
Feb 18, 2011 10:41 PM
Macamon
Apr 17, 2009 10:36 AM
coop923
Feb 23, 2009 03:12 PM
