Need Help Finding New EEC
Old Jan 30, 2026 | 05:57 PM
Fixitagain1990's Avatar
Fixitagain1990
4wd Low
Hi all. I'm looking for help to identify a suitable replacement EEC. I'll throw in some further notes as I have no post history, new member. Backstory: My truck started misfiring/backfiring on the way home from work a while back. Risked it and limped home. Idled for about 45 seconds after I parked and it shut off on its own. Solid CEL, self test won't engage. I hear a click and fuel pump primes when I try to start self test, but nothing else happens. I'm suspecting my issues as well as the faulire to start self test are due to EEC going out. Replaced EEC relay which was slightly melted. At this point in time, truck is starting and idling just fine. After warming up, I can step up to fairly high rpm (no tach) and she isn't shutting off like before. Further notes: Truck at times does shut off immediately after cranking, very up/down surge/die idle when firat starting the truck. Fans speed up intermittently as well at startup.
Old Jan 30, 2026 | 07:23 PM
Fixitagain1990
4wd Low
Nothing really stood out to me as bad when I had it out, but here are some pictures in case I missed anything.
Old Jan 30, 2026 | 07:39 PM
90project5.0's Avatar
90project5.0
Looks like this capacitor is starting to leak. Notice the bright green buildup just under the right side as well as the brown staining going towards black chip to right.
Old Jan 30, 2026 | 07:55 PM
Fixitagain1990
4wd Low
I believe that image is from a related post by @VGVForrest
Old Jan 30, 2026 | 08:18 PM
90project5.0
Sorry! No clue why that was mixed in your photos when I clicked on them…
Old Jan 30, 2026 | 08:23 PM
90project5.0
The board looks clean, but that one cap is known to go out. It could possibly still be defective, just not obvious sign. The relays on your truck are a known problem and there are a few write ups on swapping to a newer style. With it looking melted, you verified the wiring isn’t compromised? Still cannot pull codes after changing ecm relay?
Old Jan 30, 2026 | 08:54 PM
Fixitagain1990
4wd Low
That one cap is known to go out.
Which cap is known to go out? Maybe I can test it. I'll attach an image of the relay harness. Everything is still making contact, but will replace ASAP. And that's correct, still no codes just a solid light.
Old Jan 30, 2026 | 09:15 PM
90project5.0
Rough looking! You can probe the wires about 6” away from the connector and check each one for continuity while wiggling the connector to see if it breaks.
This is your pic, I made sure haha!
Old Jan 30, 2026 | 09:16 PM
90project5.0
Do you have a code scanner or just trying to read the blinking check engine light?
Old Jan 31, 2026 | 12:38 AM
Fixitagain1990
4wd Low
Tried going off the dash, also used the test light method. I just ordered a set of replacement caps, not sure when they'll be in. I'll pull the EEC back out when I can and put a light behind it, really had my hopes up she'd run fine after replacing the relay lol. As far as a potential replacement, where my sticker says E9TFAR1A, that's what I'd be looking for right? I see a Cardone Reman labeled E9T-FARA.
Old Jan 31, 2026 | 04:50 AM
manicmechanic007's Avatar
manicmechanic007
Is it in a 52 Packard?
Old Jan 31, 2026 | 07:45 AM
My4Fordtrucks's Avatar
My4Fordtrucks
The fuel pump continues to run or it shuts off after a couple seconds? Nothing else like no spark?
I put you calibration code in the search engine and got these threads
and this post
Old Feb 1, 2026 | 04:24 AM
Fixitagain1990
4wd Low
After fuel primes it, fuel pump shuts off. I ran into a crank but no start issue a while back. ICM and coil were both fried. After that, truck ran great for a while. Maybe a week. No CEL, nothing. Then I ran into the current issues.
Old Feb 1, 2026 | 06:48 AM
90project5.0
What brand ICM did you use?
Also, on your original post, at the very end you said the fans intermittently speed up when starting. What fans?
Old Feb 1, 2026 | 07:36 AM
My4Fordtrucks
and is it the correct one for whatever model year car/ truck/ van/ motorhome the OP is working on.
