Hey guys, recently picked up a 1990 F350 with the 5.8l 351 EFI. On acceleration I get a flashing check engine light but I don't feel any stuttering or hesitation common with a misfire. Most of my Google searches are telling me I have a misfire under load with the AI telling me I'm experiencing a catastrophic failure that I apparently cant feel. I plan on trying to read stored codes tomorrow, but was curious if anyone else has had this. I plan on doing an ignition tune up and replacing wires/plugs because it has been about 5 years since they were done (based on what I can tell from scattered records in the glove box). Also curious if there are any other common culprits. Thanks!
^^Start here ^^ That computer is not capable of detecting misfires. You are guessing at the problem if you don’t check for Key On Engine Off (KOEO) codes first.
If he had a unicorn that had a working knock sensor, could that not detect one? I would imagine it would need to be bad enough for OP to feel though… I know they are designed to retard timing, just curious!
Checking codes is vital!
It would have to be a unicorn since the OP’s truck has
Originally Posted by Sgtshortbuhs
the 5.8l 351 EFI.
which does not have a knock sensor and nowhere in the block to install one.
My 5.0 does the same thing, CEL flashes when on the gas and goes out when at steady state, or coasting. Mine has been that way for many years and does not seem to make a difference in how it runs. However, the thing only runs on seven cylinders, but it has been that way for many years now, too. It may, or may not be a significant issue, but reading the codes will be the place to start.
That should not happen and suggests a fault with the computer, a properly function computer would turn the CE light on constantly the whole time if there was a serious issue. I suspect you will also find there is no response from the computer when trying to pull codes. None of this would be surprising for an original computer(ECM/PCM) of this age, it's well beyond its "best before" date.
I'd suggest pulling it out for an inspection, failed capacitors are common but so is water damage from leaking windshield adhesive. In this truck the main wiring harness detaches from the engine bay side while the computer has to be pulled from inside the cab via the drivers kick panel. Don't forget to disconnect the battery first.
The 5.8 likely didn’t have a knock sensor because ford never intended the engine to use one. Either because they had lower compression, less ignition advance, or something else which meant it would be less likely to knock to begin with. A knock sensor on a 5.0 could have been to use more aggressive timing advance without concern for damaging the engine , or for driveability refinement
the simple reality is that a 5.0 302 knock sensor would not translate to a 351 5.8 because the block is different and the tuning and location of the knock sensor was fairly engine specific
same thing with gm at the same era , trucks got 1 sensor and some cars got 2 but they had different rotating assembly and timing curves and such
the 4.3 got two but they were maxing that thing out for power, likely done there to use all the timing advance they could stuff in it
