Transfer case leaking at case seam
Old Jan 29, 2026 | 05:18 PM
yewdall's Avatar
yewdall
2005 Ranger, 1354 transfer case. It seems to be leaking at the seam where the two halves of the transfer case come together -- always dripping, and loses about a quart every month. Leaves a fairly good size puddle overnight. It's a used transfer case from a recycler that I put in last summer to replace my original that had some other issues, and I figured someone probably split the case at some point and didn't reseal it right. It is not leaking from the output shafts. though it is a little noisy at times.
So I figured I'd take it out, again, and reseal it and put new bearings and whatnot in it while I was at it. But... none of the kits that I'm seeing include a gasket for the joint between the two halves of the transfer case housing. What's up? Does that joint just seal with RTV or ?
Thanks
Zeke
Old Feb 16, 2026 | 04:05 PM
wayneadiego's Avatar
wayneadiego
4th Gear
Best to use is Non-Acid Cure Silicone Rubber or equivalent , a gasket may give to much internal clearence.
queen of spades
Nov 20, 2025 12:00 PM
TheWhiteBeast
Sep 17, 2011 09:50 PM
03XLT4x4 Flareside
Dec 21, 2004 08:47 PM
cryptonik420
Dec 3, 2002 12:57 PM
sparky
Jan 14, 2000 07:07 PM
