EAB bearing clearance
Old Jan 27, 2026 | 03:55 AM
Goshencars's Avatar
Goshencars
I was checking my crank mains and rod diameters and they are .003 under.This seems to me to be at the max but I don"t want to do a regrind. I haven"t ordered new bearings yet and the journals are .010 under. I was wondering what you guys thought about it. If I find the clearance to be greater than.003 when I install the new bearings I might discover some cap stretch. I have some tapered shims that I can use. Years ago we used them all the time. There wasn't any plasigage back then and we just put a small piece on .002 shim stock on the throw and torqued it down. If the crank was bound we figured we were good. If the crank turned we tried a thicker shim until it did bound, then we put in the required tapered shim and rechecked with the .002 shim piece. I think I cam keep the .003 clearance . Is that too much clearance? I'm building a show truck, not a dragster, but I don"t want to do it over. Thanks.
Old Jan 27, 2026 | 06:30 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
According to Ford documentation in my library:
The main bearing journal clearance is 0.0010 - .0025
Connecting rod journal clearance is .0008 - .0033
Old Jan 27, 2026 | 07:05 AM
Goshencars's Avatar
Goshencars
Thanks for that information
timbersteel
15
Oct 29, 2013 06:34 PM
darrin1999
Jan 7, 2007 09:11 AM
ford390gashog
Feb 12, 2006 01:57 PM
141bpm
May 8, 2005 07:45 PM
boond0cksaint
17
Sep 28, 2004 08:25 PM
