bearing clearance?
Old Feb 11, 2006 | 09:45 PM
ford390gashog's Avatar
ford390gashog
bearing clearance?
well i am getting the 352 finished. i am building the short block right now. but have a few questions. the crank was turned 10/10 on the last rebuild before i got it and i have not done any machine work. i have just honed the walls and cleaned the crank. i have .020 for all the crank bearings and .0013 for the piston to bore clearance. do these seem ok?
Old Feb 12, 2006 | 11:04 AM
rusty70f100's Avatar
rusty70f100
The piston to bore clearance seems fine. The bearings, however, do not! They should be like .001" to .003", not .020"! Maybe you typed it wrong and meant .002"?
Old Feb 12, 2006 | 11:19 AM
fordeverpower's Avatar
fordeverpower
something like .001 to .0025 max for bearing clearence. Something toward the higher side, i would opt for thicker oil and high volume pump, tight clearences just the opposite. I am not saying you have to do both but i was just listing what options there are.
As for the crank journals, ALWAYS measure them with a micrometer to .0001 accuracy. 10/10 needs those bearings and 20/20 crank needs 20/20 bearings. I surprisingly have standard crank and run .001 bearings if I recall.
Old Feb 12, 2006 | 01:57 PM
ford390gashog
rusty,
yes it was a honest mistake on my part. my fat fingers missed a zero. according to the plasti gage it is spot on @ .002
dayde
Modular V10 (6.8l)
Jan 7, 2017 07:02 PM
krustiy lusti
Jan 23, 2016 05:31 PM
73 ford guy
Aug 5, 2008 09:43 PM
darrin1999
Jan 7, 2007 09:11 AM
MaximumMax001
25
Aug 17, 2004 06:02 PM
