AOD question
Old Jan 24, 2026 | 09:41 AM
70f100longbed's Avatar
70f100longbed
AOD question
I have a 86 Bronco with a tired AOD. I also have a 89 2wd AOD that has 4R70W planetaries that I was going to use in the Bronco. Will the 86 output shaft work in the 89 case? I know there were some lube circuit and accumulator changes in 89. I would like to use the better case due to 351 swap plans. I was going to use a Transgo shift kit that lets you tune the 1-2 shift.
Old Apr 23, 2026 | 06:42 PM
70f100longbed
Just an update if anyone is interested. I found a 89 4x4 output shaft from a trans shop in NJ. Got the trans built with 4r70W internals. Used the Transgo shift kit and installed the blue spring for the 1-2 capacity valve and a low speed governor. Trans shifts great and does not wind out 1st gear at all. The lower 1st gear ratio is very nice too. Highly recommend for an AOD build.
blueblood73
1978 - 1996 Big Bronco
Aug 1, 2017 01:33 PM
jimyz250
Dec 25, 2012 07:23 PM
the bull 1986
Feb 12, 2009 09:31 PM
Hchadda
Feb 10, 2004 06:06 PM
