Wiring Question '92 Ambulance
Old Jan 23, 2026 | 06:56 PM
Silentblaze357's Avatar
Silentblaze357
4th Gear
Background, the transmission has been fully rebuilt and I went to start the truck, this connection smoked and melted.
Hello, I am trying to figure out why this connection is melting. It looks like a cable that is coming from the starter is melting it. The starter does turn, but the truck does not turn over. It would heat up rapidly to smoking when I tried to turn over the engine.
Old Jan 23, 2026 | 07:08 PM
85e150's Avatar
85e150
Welcome to FTE.
Please clarify:
"...starter does turn..." "...but the truck does not turn over....".
If the starter turns and the engine does not, then the starter is not connecting with the ring gear and you have a mechanical problem in that area.
If you mean that the starter turns but the engine does not start, that's something else.
As to why the connection is melting, what is that connection for? Where do the wires lead? Have you worked on that wiring bundle?
Things smoke and melt due to overload or dead short. Check for both.
Old Jan 23, 2026 | 07:48 PM
Silentblaze357
4th Gear
Hello, the starter turns but the engine does not start.
The wires that lead to the starter are the ones smoke and melt. I cleaned up the connections and removed the melted plastic.
Old Jan 23, 2026 | 10:07 PM
ihc1470's Avatar
ihc1470
Might mark on your picture which wires. In most cases wires smoke and connectors melt due to high resistance connections or excessive current demands. How fast does the starter actually turn? Your issue maybe as simple as a bad starter. Have you looked at this link? starter
Old Jan 24, 2026 | 06:08 AM
Olds64's Avatar
Olds64
Make sure your battery cables are in good condition. Split jackets, smashed terminals and green corrosion are a big NO NO.
Old Jan 24, 2026 | 06:14 AM
charlie g's Avatar
charlie g
FTE Community Team
are there PINCHED wires between the block and trans now? sure sounds like a strong possibility
Old Jan 26, 2026 | 08:21 AM
tecgod13's Avatar
tecgod13
If that is the connection I think it is, the two larger wires on the right go to the glow plugs. That is a known weakness in the harness, the plastic will melt and there won't be a good connection there. You can cut them out of the connector and find a way to bypass it. I think some people just cut the connectors from the glow plug wires and use a butt connector on them.
Since those wires go to the glow plugs, the glow plugs aren't working right and that is why you're having trouble starting the engine. Make sure you fully charge up the batteries while fixing the wiring and see if that helps.
Old Feb 7, 2026 | 07:18 PM
Silentblaze357
4th Gear
Hi tecgod13, Thank you for your expertise. It does connect to the glow plug relay. I will cut it out and bypass the harness to see if it works.
Old Feb 9, 2026 | 07:59 PM
Silentblaze357
4th Gear
Yup, bypassing the harness and connecting the yellow wires directly worked like a charm.
Old Feb 17, 2026 | 12:25 AM
ObeFunOne's Avatar
ObeFunOne
1st Gear
Hunting for a wiring diagram
Im hunting for a 1991 ford f350 idi 7.3 diesel non turbo international lariet (sp) ambulance package wiring diagram. The previous owner hacked up the wiring harness and im trying to put it back together, and for the life of me I can not find a diagram for this. Im trying to wing it but its not working.. any help would be amazing!
Old Feb 17, 2026 | 10:40 AM
BigBlue2's Avatar
BigBlue2
Have you looked into getting a Ford service manual for your year? Seems they are available on ebay in several formats, book and CD. I'd check there or possibly used book stores in your area.
vhariable
Sep 1, 2024 12:08 PM
Heavenword1
Jul 14, 2013 09:51 PM
projectdagger
May 14, 2013 01:26 AM
eddie v
Dec 7, 2010 04:27 PM
ken.cover
24
Jul 1, 2009 05:24 AM
