1978 - 1996 Big Bronco
Tailgate Window Question
Old Jan 18, 2026 | 03:48 PM
robjs111's Avatar
robjs111
Tailgate on my 96 bronco will only go up/close but if I switch polarity on motor tailgate will only go down/open. Key switch on tailgate and dash both operate the same, one direction only.
Fuse 12 and 14 CB are functioning. Constant power to tailgate switch was working so I jumped constant 12 v from fuse 5. Tailgate window motor is new. Grounds are dash are good. What possibly could be issue?
Old Jan 18, 2026 | 04:14 PM
RSCHAP1's Avatar
RSCHAP1
I have had to work on nearly every one of my Bronco's tailgates.
I thought the reversing of polarity was how the motor went both directions.
Found this in case it helps.
1996 Bronco Tailgate Wiring Diagram - Wiring Diagram
Old Jan 18, 2026 | 04:48 PM
robjs111's Avatar
robjs111
What I mean by reversing polarity on window motor is physically switching leads to motor then window does go up but not down from either tailgate or dash switch.
Old Jan 18, 2026 | 06:09 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Latches…
So you are bypassing the switches (dash/ key) and applying power directly to the window motor? Is the tailgate open or closed?
Old Jan 18, 2026 | 06:56 PM
robjs111's Avatar
robjs111
I deleted the tailgate safety switch so that is not an issue.
What I did was run a separate ground wire from pink/grey wire on tailgate switch to chassis and switch works both up and down. Only issue is dash switch not working.
Old Jan 19, 2026 | 05:10 AM
manicmechanic007's Avatar
manicmechanic007
There are limit switches inside the tailgate
Those limit switches and the safety switch control the motor function
Fixed about a thousand and the limit switches were getting hard to find even in 1997
You put a garbage can under the window with a towel on it with the tailgate down (to support the glass while you test and replace the limit switches)
Pushing the limit switches with a long screwdriver will allow you to force the window up and "out of the tailgate" and onto your garbage can (glass will be completely out of the tailgate)
Then you can replace the limit switches while the glass is out
Then reinstall the glass
Old Jan 19, 2026 | 06:35 AM
My4Fordtrucks
No idea why you would do that.
Have you checked the wiring between the body and tailgate for broken or frayed wires?
Old Jan 19, 2026 | 11:55 AM
robjs111's Avatar
robjs111
Where exactly are the limit switches located?
Thanks
Old Jan 19, 2026 | 03:47 PM
manicmechanic007
The ends of the tracks, follow the wiring
They are behind the glass
That's why you need to shoot the glass up and out to check and replace them
TicoTube
19
May 3, 2013 03:03 PM
blue&white
Mar 8, 2006 12:41 AM
entomber
Mar 7, 2004 11:11 PM
icelander
Apr 17, 2002 01:42 AM
sharlo
Dec 26, 2000 07:31 AM
