Starter crank delay
Old Jan 11, 2026 | 08:16 PM
Freestate's Avatar
Freestate
4wd High
Starter crank delay
Hello people. Second owner of an F100 finishing up an off frame restoration. The truck is a 1979 F100, 6-300, origanally a 4spOD toploader swapped to a t18 in 1998(ish). When I turn the key to start, there's a 2 or 3 second delay between turning the key and the starter actually cranking. I assumed this is normal because when I first bought the truck in the 90's it did the same thing. But, I've been told the motor should crank as soon as I turn the key to start.
The truck was parked in a hayfield from 2002 until I started the restoration in 2025.
Is the weird several second delay normal or am I missing some oddball problem?
Old Jan 11, 2026 | 08:47 PM
Wangdangdoodle's Avatar
Wangdangdoodle
Since this a restoration, are all your parts new? Especially electrical/wire harness? It's definitely not normal to have a delay like that.
Old Jan 11, 2026 | 08:58 PM
Freestate's Avatar
Freestate
4wd High
Starter, solenoid, ICM, coil, distributor, and a bunch of connections and several individual harness wires and connectors are new. Most of the harness, the starter key switch, wiper motor, and light switch, are original. The Sparkomatic radio installed in the 80's was re-installed.
Old Jan 11, 2026 | 09:00 PM
tbear853's Avatar
tbear853
Not normal at all in my experience. I would first suspect the start solenoid on the inner fender near the battery, second suspect would be the ignition switch.
I would clip a jumper wire, to the "S" and touch the other end to the battery positive (red) connection. Key does not need be on, ... in fact I'd leave the key in my pocket. It's not going to draw a bunch of power, it's just going to cause the solenoid to internally connect the two big terminals to spin the starter, but the engine is not going to start with key in my pocket. See if same delay.
Old Jan 11, 2026 | 11:10 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 should not have a delay, bump key truck starts. Well not all of mine are like that, but my 77 is and it is all OEM/all originial. I too would suspect your ignition switch. But a Ford ignition switch bezel removal tool or.....Carefully use a flat tip swrewdriver and tap one of the 3 front bezel ring notches (counter clockwise) to loosen to be able to remove the complete ign switch.
The tool for a better way to NOT scratch the dash; https://www.ebay.com/itm/155320684383
Or how to maybe scratch the dash.
You can remove the originial/old key tumbler (w/ the paper clip trick) and put it in the new switch body.
Old Jan 12, 2026 | 07:29 AM
manicmechanic007's Avatar
manicmechanic007
+1 for the ignition switch coming apart is the problem
Delayed connection and fire when those switches start to come apart
Old May 29, 2026 | 06:00 PM
Freestate's Avatar
Freestate
4wd High
It was the switch. Replaced it and now we're 100%.
Old May 30, 2026 | 04:38 PM
1TonBasecamp's Avatar
1TonBasecamp
Great to hear! Glad you got it fixed, and thanks for coming back around and putting the last chapter on, at least this problem. 😉😁
RECO6901
6.4L Power Stroke Diesel
17
Mar 9, 2025 06:21 PM
Kanewilburn
Oct 29, 2024 01:05 PM
El Campo
Feb 13, 2019 08:08 PM
96bigblueford
6.7L Power Stroke Diesel
20
Jan 13, 2018 06:27 PM
och
Dec 5, 2012 07:35 PM
