Injector or FICM
Only FORScan full version requires a laptop. FORSCan Lite can be put on your i-phone/device. ForScan Lite is fine.
My laptop should be coming in today. I have the adapter for the connector under the dash. I should have the forscan software loaded tonight.
This is the first time I have used forscan so any pointers would be welcome. I am troubleshooting a misfire of one or more of the injectors. What would I see on the froscan tool?
Scan it BEFORE you retune it. At least to get the codes. Pretty sure my SCT clears KAM as part of the reprogram cycle so I would lose them right?
Blade is correct to do active testing with a stock tune if possible, but IMO always scan it first in the state it's having the problem in to get a baseline.
I plugged everything in. but there seems to be no connection to the truck. I downloaded the Forscan for windows, installed it. I plugged the connector in but get nothing. Am I missing something?
You don't need a paid FORScan key to pull codes. That's only needed for some programming functions. You should be able to just plug the cable into the OBD-II port, turn vehicle key to on, check that the light on the cable turns on, press the 'Connect to Vehicle' button on the lower left, see a splash screen for your vehicle, then press the 'Read Diagnotic Troubleshooting Codes (DTC)' button on the left.
Well after putting in a new FICM I get the same diagnostic message about the FICM. So I am concluding the Forscan is showing a false fail. The #6 injector will be the next to get checked.
BTW, Does the Forscan tool have a buzz test?
The diagnostic message is from the PCM. FORScan just reports what the PCM is telling it when it pertains to codes.
A single injector code is typically not a FICM issue, but it has happened, especially on the early 7 screw FICMs that had individual drivers.
