Clunk or aggressive shift
Old Jan 6, 2026 | 05:45 PM
G7257's Avatar
G7257
4wd High
I have a 2012 6.7 f350. At low speed or a parking lot crawl it will kick into 2nd gear with a clunk, this is only at low speeds and it’s more aggressive the slower I am accelerating. Normal acceleration it shifts into 2nd smoothly. Retuned it with no joy, still kicks. Any suggestions on what this could be?
Old Jan 6, 2026 | 07:53 PM
Superdave71's Avatar
Superdave71
How many miles? When was the last time the transmission fluid was changed?
Old Jan 7, 2026 | 04:48 AM
G7257's Avatar
G7257
4wd High
127k miles, I’m not too sure when the transmission fluid has been changed since I bought it at 120k miles. However the transmission fluid looks good.
Old Jan 7, 2026 | 05:28 AM
Superdave71
The first place I’d start is drain, top off, drive it to hot then repeat. It’ll take a total of about 12qts of ULV. When you drive really easy pressures are lower and stiction in the valve body can cause more abrupt shifts. New fluid has better lubricity and that might improve
FSCboss
May 12, 2024 10:55 PM
collinsmc560
Aug 24, 2023 06:08 AM
1977-F350
23
Jul 12, 2021 12:07 PM
Blue94Bronco
1978 - 1996 Big Bronco
Nov 13, 2012 07:14 AM
Electric1
Jul 25, 2002 07:20 AM
