I am troubled with the shifting of my Expy.
When i manually shift down into 2nd and make a complete stop
then proceed to go my truck will not shift into 1st geareven if i punch it but if i put the truck into drive stop and then go and punch it it goes through the gears fine. Is this all normal?
When you manually put it in 2nd, you manually put it in 2nd. Not 1st, not 3rd, but 2nd, just like it says on the shift selector. Same thing would happen if you put it in 1st. Did you ever drive a vehicle with a standard transmission? I guess there is a whole generation whom do not know how to shift gears, sigh....
I can remember a time when automatic trannys shifted 1 & 2 when placed in 2 and its only been in the last few years that the trans programmers left that part out........Cost reductions I guess. or maybe that was before computer trannys when they had to work by themselves. I think vacuum controls worked pretty well.:-staun
Hey, I wasn't throwing stones, but I guess my comments did come off as kind of smart a$$.
The Expedition has separate gears, and you can shift through them manually within speed/torque limits. My '92 F-150 with AOD has Overdrive, Drive and 1 for forward selections. If you select 1 as you are decelerating it will shift to 2nd and then 1st when the torque is right. Upshifting is different. It will stay in 1st until you run out of gas or move the selecter. If you move to D and then back to 1 the AOD will shift to 2nd and stay there until you slow down or again move the lever to D or OD.
Really not a wise guy, just a knothead responding too soon after a trip to the dentist.
